Old 10-25-2020, 06:14 PM
firmflange's Avatar
firmflange firmflange is offline
Default "Dock Left Edit" Unassignable?
Is the "Dock Left Edit" unasignable? Every time I try to assign a function on the assignable areas, it does not function, but just goes back to the labeled default function. Is it assignable like the "Dock Right Edit" is?
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM
Slate Raven MTi2 / Artist Control
Old 10-26-2020, 11:54 AM
BigBadBill BigBadBill is offline
Default Re: "Dock Left Edit" Unassignable?
Dock Left Edit works fine for me.
Old 10-26-2020, 03:04 PM
firmflange's Avatar
Does it work fine in the sense that you can customize the buttons? I try to customize them and they revert back to the default, even though the commands are applied. Help!!
Old 10-26-2020, 08:07 PM
joeshepard joeshepard is offline
Make sure you are saving in the Eucon app after you make the change and also in the Left edit realize you need to use the ALT button instead of the SHIFT button to access the secondary button pushes.
Joe
Late 2018 Mac Mini 3.2 GHz i7, 32GB memory, 1TB SSD
MAC OS 10.15.6
UA Apollo 8 Quad Blackface, UA TB Octo Satellite
Pro Tools 20.9 EuCon 20.6.1
Artist Mix
Pro Tools Dock
Old 10-26-2020, 08:32 PM
firmflange's Avatar
Hi Joe,
Yes, I do save the App all the time. It still doesn't recognize the customizable command. Pressing "Alt" does it's function, but only with the default commands.
Old 10-27-2020, 02:55 AM
Well that just sucks.
It works for me but I'm on Catalina and a 2018 Mac Mini
Boo Hiss
joe
MAC OS 10.15.6
Artist Mix
Pro Tools Dock
Old 10-27-2020, 09:08 AM
firmflange's Avatar
Anybody else have any ideas? I have tried looking at all the options and the preferences and can’t find anything.
Old 10-27-2020, 02:35 PM
I'm sure you did this already.
Have you checked you to see if your firmware versions are up to date in the EuControl settings?
MAC OS 10.15.6
Artist Mix
Pro Tools Dock
Old 10-28-2020, 05:06 PM
firmflange's Avatar
Firmware is 20.6.1.3
Old 10-31-2020, 11:11 AM
firmflange's Avatar
Anyone?
Eucon "Left Edit Control" & "Right Edit Control" skilletaudio Avid S6 4 11-15-2019 08:09 AM
Pro Tools Dock "Clip" light the lower left corner is not bright hjy00000 Avid S1, S3, Dock and Control 5 02-12-2018 01:24 PM
SOLVED - Dock Left Edit "Shift" greyed out simonchase Avid S1, S3, Dock and Control 5 03-14-2017 12:50 PM
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 09:14 AM
"Space" in Edit Window, to the left of Bar 1 ?!? LSNY macOS 1 05-29-2012 08:47 PM
