Old 01-18-2011, 02:46 AM
shiama shiama is offline
Default Sc 48 firewire port
Hi all,
next week I have a show , I ll bring only my laptop and I will find a Sc 48 venue in the theatre. I have PT LE 7.4 cs10 and I am runing it from an old MBP , on my laptop I have only 1 firewire 400 port. Is this ok with the Cs 48? Since I v never used I would like to be sure that everything is compatible. On the Digidesign specification web page is not specified if is a Fw 400 or 800. Plz help
Thanx in advance
Shiama
Old 01-18-2011, 03:02 AM
Default Re: Sc 48 firewire port
Probably I need to understand if venue compatible with PT LE 7.4
I can't find any specification regarding software compatibility.
thanx
Old 01-18-2011, 05:53 AM
mariojorgeandrade mariojorgeandrade is offline
Hi.
It's a FW400 port in a SC48, although you can plug into your computer's FW800 port using an adapter, that's what I do.
I use PTLE 8.04, but at the time it was released, people already used FWxs, so it's compatible, I bet.
I'ts very easy to setup and record, but since you're still limited to 18 tracks, if you have more inputs than that, you must group some, using auxes, groups, matrixes, etc.
In this case, a little bit of planning beforehand helps a lot.
Assign them at the Patchbay.
I created a template for FWx recording in PTLE, it saves a lot of time, too.
Finally, Don't forget to turn on the direct outs, being from input ou output channels, on the SC48 there's no front panel surface control fot that, you can turn it on at the inputs page and adjust their level at the patchbay.
Good luck.
[]'s
MJ
Old 01-18-2011, 10:19 AM
Hi Shiama.
It IS compatible.
Read that:
Additional Requirements
The following are required to use the FWx Option Card with your VENUE system (Pro Tools LE hardware is not required):
* Avid-qualified FireWire-equipped computer running Windows Vista, Windows XP, or Mac OS X (see "Compatibility Information," below)
* Compatible Pro Tools LE software for your computer:
o Windows Vista Business or Professional: Pro Tools LE 7.4 or higher software
o Windows XP (with Service Pack 2): Pro Tools LE 6.7 or higher software
o Mac OS X: Pro Tools LE 6.9.2 or higher software
At: http://www.avid.com/US/products/FWx-Option-Card
Regards,
MJ
Old 07-27-2018, 08:32 AM
Thanks !! Loging in after soooo many years....
Questions on USB/Firewire speeds on computer W/ No firewire port rockguitarist1255 Tips & Tricks 14 04-02-2013 06:35 PM
Impossible to find SIIG FireWire 2-Port ExpressCard FireWire adapter Bloody Maker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-22-2010 09:58 AM
FW800 port —> FW800 Drive —> Out FW400 port on Drive —> Pro Tools LE FireWire maharzan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-03-2009 08:37 AM
2 Firewire devices.1 firewire port (macbook pro) TBF Entertainment Pro Tools M-Powered (Mac) 10 09-16-2006 01:28 PM
How can you use an external firewire drive and Digi002 with only 1 firewire port? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-16-2003 01:11 AM
