Old 03-17-2009, 01:00 AM
polnetwork.com polnetwork.com is offline
Default Automatic loop on open for video installation
Hello, I neeed to do a video installation with dual screen and some audio automation with input mics.
The video shoul be a infinite loop (region selection + loop play)
Now I need to setup up an automatic region selection on project open for simple play/loop because a non tech person will be who starts the system every day.
Is it possible?
Thank's!
Pol Maresma
Old 03-17-2009, 01:17 AM
Default Re: Automatic loop on open for video installation
Now it's done with a memory location (as a selection), can I set a default memory location for a project?
thank's!
Pol Maresma
Old 03-17-2009, 03:26 AM
tj_davies tj_davies is offline
thank's!
Pro Tools saves your selection.
So if you make your selection, save and close/quit Pro Tools, then the selection will be active when you load that session again. All your tech would need to do, is press PLAY.
Does this help?
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 03-18-2009, 01:48 AM
Thank's! I will try it.
see you
Pol Maresma
Pro Tools will not open after power cut during installation joey141 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-07-2009 11:50 AM
HELP-cannot open plugin' after installation! waynec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-01-2007 09:51 AM
reboot loop after installation of version 6.4 Dennis Squier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-02-2007 08:44 PM
reboot loop after installation of version 6.4 Dennis Squier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-02-2007 04:37 PM
Canopus DV video and Automatic delay compensation PeterB Pro Tools TDM Systems (Mac) 3 07-25-2005 04:20 AM
