Old 03-06-2003, 06:35 PM
tenkproductions tenkproductions is offline
Default ASIO Driver Not Working!
I've been trying to get the asio driver to load and when i install it I get your version needs to be 5.3.1 or higher.I have 5.3.3 installed.What the F**^^& is up with this !
Any help would be grateful!
Phil Plaskon [img]images/icons/grin.gif[/img]
www.tenkproductions.com
Old 03-07-2003, 10:14 AM
Dave Lang Dave Lang is offline
Default Re: ASIO Driver Not Working!
Hi Phil,
I had the same problem.
Uninstall ProTools, reboot, then install the ASIO driver.
Now you can install ProTools and everything should work.
At least it did for me. [img]images/icons/smile.gif[/img]
Let me know how it turns out,
dave
Old 03-07-2003, 06:49 PM
Thanks
I'll give it a try.Which version of the asio driver are you using b1 or b2 and are you using wavelab.
Phil [img]images/icons/grin.gif[/img]
Old 03-07-2003, 07:32 PM
Using B2 and not using Wavelab...
Old 03-08-2003, 07:23 AM
Thanks Again
Old 03-08-2003, 08:04 AM
Did it work?
Old 03-08-2003, 08:10 AM
George Ware George Ware is offline
I had the same problem. I uninstalled PT TDM and re-booted and installed b2. The digi ASIO works better with Acid 4.0b, even with my old 882 I/O so I sold my MOTU-2408s. [img]images/icons/cool.gif[/img]
George Ware
Mac Money Studios
Old 03-08-2003, 04:56 PM
Dave
I can't believe it but it worked.I'm running Wavelab and all is well who knew.Tell Digi to put this in there install notes!!!! Ha
They should write the drivers and install the right way the first time around!
Phil
[img]images/icons/grin.gif[/img] www.tenkproductions
Old 08-09-2016, 03:27 PM
johnkuhn johnkuhn is offline
I'm about to try this I have ASIO driver for M-Audio Mtrack Quad , I7, Ge Force 745, Windows 10 .. could it really be as easy as uninstalling and reinstalling ASIO first? I cant get it to let me adjust sample rates or anything wish me luck
Old 08-09-2016, 03:28 PM
oh **** this was back in 03!!!
ASIO Driver Zoom H4n not working w PT10 Kinnerfelt Windows 2 07-17-2012 09:59 AM
ASIO MBox Driver Not Working!? Markus7 Pro Tools 9 2 12-08-2011 01:48 PM
Is the 003R ASIO driver working in Win7 yet? dwells Windows 1 10-02-2011 11:58 AM
This old cookie: ASIO driver in XP, still not working for me. danlea 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-28-2010 06:42 AM
ASIO Digidesign Driver not working in other programs treasureplane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-13-2008 09:55 PM
