  #1161
Old 08-15-2013, 07:05 AM
louieshowers louieshowers is offline
Default Re: Control|24 with Pro Tools 11?
Originally Posted by Kenny Gioia View Post
Sure it is.
Have we improved the ADB keyboard that those Macs used to have?
What about Ultra Wide SCSI 10,000 RPM drives?
The bottom line is that nobody supports computer hardware that is 12 or more years old. Doesn't matter whether or not it still works well. Companies move on.
I'm with you guys. I think Avid should make the driver but these analogies all fail.
How are you "with us"? How can you expect people to believe this when you have justified Avid's decision in greater detail than anyone else on this thread? They made a $15,000 product unusable on purpose at the same time they released a complete rewritten PT! They used the "i gotta have it" mentality to drive update sales and (get ready for it) hardware sales. This was a strategy that was identified and rejected by customers that are too damn smart to flock like sheep with their checkbooks at hand. How can you dispute this. And good for Shane for really showing expertise and dedication to helping people here.
Windows 7 64 Ultimate: SP1
PT 10.3.8
¨WHERE´S MY CHECKBOOK?¨
https://soundcloud.com/louieshowers
  #1162
Old 08-15-2013, 08:29 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Originally Posted by deanrichard View Post
... for Avid to pay someone to make these changes while working on the internals of the PT software, supporting the Control 24 is not an expensive proposition. ...
How do you explain the fact that the faders on these controllers work better than HUI if it's really only a MIDI controller? Might not the presence of one of these controllers trigger running Pro Tools in some different mode that may have been baked into low level code? If this is the case, it certainly could make supporting 11 a VERY expensive proposition.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #1163
Old 08-15-2013, 08:55 AM
michael c michael c is offline
This is why it would be in Avid's best interest to truly explain why it isn't economically feasible for them to write drivers for ProControl and Control 24. I think their user base would feel much better about buying expensive controllers in the future if they knew why their perfectly useable controller and center piece of their studio won't work now.
  #1164
Old 08-15-2013, 09:06 AM
The bottom line is that nobody supports computer hardware that is 12 or more years old. Doesn't matter whether or not it still works well. Companies move on. The only devices that still work past that amount of time are units that don't need newer drivers. Like a USB mouse or keyboard. If they needed a new driver, they wouldn't be written as the company probably makes newer devices that they continue to support.
Kenny-
I get your point, but we have an old Mark of the Unicorn Midi Time Piece in one of our set ups that is over 25 years old and still works! MOTU wrote a new driver for that just a few years ago and they have several new and improved USB midi boxes out.
Obviously, there is always the exception. As has been stated several times by many Avid supporters, it is a bad business decision to alienate your high end user base when you are rolling out a new product such as PT11 and HDX.
  #1165
Old 08-15-2013, 09:49 AM
Originally Posted by michael c View Post
This is why it would be in Avid's best interest to truly explain why it isn't economically feasible for them to write drivers for ProControl and Control 24...
Revealing proprietary information may well not be in Avid's best interest. They have already said it would be too costly and you say they are lying. That's really the essence of this argument.
Interview
  #1166
Old 08-15-2013, 09:51 AM
Delivering these drivers is in their best interest. Experienced and knowledgeable people know they are lying. I think that is a better way of wording it.
PT 10.3.8
  #1167
Old 08-15-2013, 10:19 AM
deanrichard deanrichard is offline
Bob, you're talking about a difference in fader resolution. That's a trivial software problem, likely solved at the messaging layer. Inside the bowels of the PT software you have internal resolution higher than any device will likely attain, or that you will need. Some controllers faders only have 128 (0-127) steps, others have 512, 1024, etc. So you do simple bit-shifting or mapping to match the internal resolution. Let's say the internal fader resolution is 16-bit (likely higher, but for argument's sake) and you're using a MIDI controller with 8-bit resolution. You simply bit-shift, which will fill the most significant 8 bits when passing messages to the internals.
BTW - I'm not the one who said the Control 24 is basically sending MIDI messages via ethernet. I was not aware that was true. Shane is the one who has successfully done remapping of the Control 24 messaging - and I give him a ton of credit for that. And the people who want their Control 24's to work in future versions should be offering him bribes right now. I checked into the AHK macro language he mentioned, and it's interesting stuff. I had no idea how powerful some of it is.
  #1168
Old 08-15-2013, 10:20 AM
Dave Lang Dave Lang is offline
Nailed it. And I think they're lying.
  #1169
Old 08-15-2013, 10:21 AM
I prefer the term "exaggerating". Dramatically.
  #1170
Old 08-15-2013, 10:31 AM
YYR123's Avatar
YYR123 YYR123 is offline
Either way they have pissed off the faithful - and it will not easily be won back
But it seems they are more interested in selling video systems to movie houses that use newer control surfaces instead of audio studios
Daniel
Vote for Control 24/ProControl drivers for Pro Tools 11 tekis ProControl, Control|24, Command|8 14 05-10-2015 05:14 AM
ProControl Vs Mc Control? surroundnoob ProControl, Control|24, Command|8 2 08-13-2011 04:05 PM
Should I get a Control 24 or ProControl??? A Spooner ICON & C|24 3 03-23-2005 10:59 PM
Should I get a ProControl or Control 24??? A Spooner ProControl, Control|24, Command|8 6 03-17-2005 10:48 AM
