Old 04-10-2002, 03:53 AM
TOMMA TOMMA is offline
Default HELP! My MIDI IN doesn’ work.
The MIDI output is ok; yesterday the MIDI input was ok, too. Today I can’t record MIDI from my external controller via digi 001!!! WHY ???
I have changed the MIDI cable but nothing!
Probably I have changed some general parameters because MIDI IN doesn’t work in all the session I’ve made.
Please help me. Thank you.
Old 04-10-2002, 01:27 PM
Kev Kev is offline
Default Re: HELP! My MIDI IN doesn’ work.
You might have to 'reset' the keyboard as a midi input device.
Track record and track record enable...?
Just go through each parameter one by one and you will find the changed one.
Have a look at OMS to make sure there hasn't been a change there.
Old 04-10-2002, 03:48 PM
I’ve resetted my MIDI configuration step by step (OMS setup and links)- it’s so symply that I don’t believe it doesn’t work! I fear it is a heavy problem !
Thank you Kev for your attention.
Any suggest?
Old 04-10-2002, 04:49 PM
accession accession is offline
Hi Tomma,
Like Kev said, check the Input Device box (under the MIDI menu) to see your synth(s) are still enabled.
Phil
Old 04-10-2002, 05:00 PM
I did it 10 times!!!
Sorry Phil, but I'm going crazy.
Old 04-11-2002, 12:06 AM
Kev Kev is offline
Does the keyboard still work in local mode ... err.. still make a noise when you hit the keys?
Do you have another midi module that can tell you if this keyboard is sending midi data?
Old 04-11-2002, 04:41 AM
I have tryed with another keyboard: the problem is in ProTools or in Digi 001
Old 04-11-2002, 05:01 PM
YES !!! I HAVE FOUND THE “ERROR” !!!
That’s incredible : there are two MIDI cables broken, so when I changed the first cable with another one,I believed the cables were ok and that the trouble was in my synth.
So I used another keyboard but nothing changed (the trouble was in the cable!).
Then I resetted 100 times my MIDI configuration in ProTools: nothing!
I was in despair but I restarted from the beginning and I founded the answer:
TWO BROKEN CABLES !!! THIS IS BAD LUCK !
Anyway, it’s ok now.
Thanks to all of you for your support and excuse me for my stupid error (and for my bad english, too)
Tomma
Old 04-12-2002, 12:05 AM
liztening liztening is offline
Are you SURE you have selected your current keyboard/controller/interface as an INPUT DEVICE within your ProTools session ?
NOT just in your OMS Set up??
l.
Old 04-12-2002, 12:29 AM
I followed all the instructiones one by one (my answer is YES: I do it ten times).
Mbox doesn´t work Hrolfursaem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-23-2011 11:06 AM
Adat In on 192 doesn´t work kolo Pro Tools TDM Systems (Mac) 3 04-30-2006 06:04 AM
My two day 002 doesn´t work already!!! Punkest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2003 10:07 AM
It doesn`t work - on 3 different PC´s schrodis Digidesign Hardware & Software 7 11-09-2000 10:09 AM
3 interfaces doesn´t work with mix plus?? stefan. Pro Tools TDM Systems (Mac) 3 11-09-1999 08:35 AM
