Old 02-13-2019, 04:41 PM
northamtrans northamtrans is offline
Default Re: Pro Tools 2018 use with 192 I/O
Originally Posted by aaquilato View Post
lea777
Thinking about upgrading to PT12.
I run OSX 10.8.5 with a PCI based PT10HD4 system.
Since my "Hack" has a digital output I can also run PT11HD Native using my UA192 as the DA converter
Can you tell me if I can use an Omni interface to launch PT 12 and still use my older Blue 192 as i/o?
AQ.
I'm a little late to the game and came here looking for info on using the 192 still. I too have a hack and was wondering if you could elaborate on the 192 through the digital input on the hack.
I have access to a card and 192 but have Vanilla but I think I can't use those two together unfortunately.
Old 02-13-2019, 06:16 PM
aaquilato's Avatar
aaquilato aaquilato is offline
Default Re: Pro Tools 2018 use with 192 I/O [solved]
Did I just answer your PM question?
AQ.
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9
Black Lion modified OMNI HD w/XB clock
Multiple Black Lion modified 192 FM/XB interfaces
Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native)
Old 07-09-2019, 09:38 AM
ghestudio ghestudio is offline
Good afternoon friends of the forum, I'm in Brazil and my first doubt:
I have a 192i blue, next to a HD Core board, currently running 10HD protools. Will it work with Protools 2018? Anyone using hd core card, acell etc with this system, or would it just work via omni?
Thank you
Old 07-09-2019, 09:56 AM
BScout BScout is offline
Core cards and Accel cards will absolutely not work with anything past 10HD. No version of Pro Tools 11, 12, 2018, or 2019.
The 192 (with adapter cables) will continue to work with the new cards (HDX) made by Avid.
Old 07-11-2019, 01:02 PM
JFreak's Avatar
JFreak JFreak is offline
Thank you
Hi, welcome to the community.
As said, HD is not supported with 64bit PT starting with 11.0 so you will need either HDX or HDN -- but you can still use the old blue-faced DigiDesign branded interfaces. The new smaller DigiLink connector is electrically compatible with the original larger DigiLink connector, all you need is an adapter. As long as you have a card with the new small connectors (HDX/HDN) that are supported with PT11 and later.
Janne
  #16
Old 03-09-2020, 12:28 PM
jjonah jjonah is offline
I have 192 io and HiSierre Pro tools 19 doesn't work The interface does not function
It seems some people found a way to solve this
  #17
Old 03-09-2020, 02:54 PM
JFreak's Avatar
Have you upgraded lately? Since PT12.6 you also need a DigiLink i/o license
Janne
  #18
Old 03-09-2020, 11:15 PM
Thank you So if I buy the Digi link License my Blue 192 io will work with 2019 ultimate?
  #19
Old 03-09-2020, 11:16 PM
JFreak's Avatar
Yes. Though be aware that the old blue DigiDesign branded interfaces are not supported, but are still working as always.
Janne
  #20
Old 03-10-2020, 10:39 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I was told the only reason 192s aren't officially supported is that a chip they use is no longer available as a service part.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
Solo Safe Not Working in PT 12 nor 2018.1 [solved] Aquic macOS 1 02-05-2018 04:53 AM
PT 2018.1 crashes on boot, 12.8.3 worked perfectly [SOLVED] aklru Windows 5 01-30-2018 02:26 PM
Anyone else missing trim plugin after 2018 upgrade? [solved] ratava911 Pro Tools 2018 4 01-30-2018 06:08 AM
