Old 07-10-2022, 10:26 AM
Crutchofmemory Crutchofmemory is offline
Default Mix Window Glitchy & Edit Window fine on single session!
Hello! Please help. The mix window on our Protools 2019 is glitchy in one session, while the edit window is normal. This issue is only with a single session, not others. We work with a Mac OS Mojave 10.14.
Things we've tried:
-Trashing the preferences
-Restarting protools and/or computer
-turning off wi-fi
-exporting the audio and creating a new session (in case the one we're working with is corrupted)
Old 07-10-2022, 11:04 AM
Ben Jenssen's Avatar
Default Re: Mix Window Glitchy & Edit Window fine on single session!
And how did that work out then?
Other things to try:
Open the faulty session whilde holding 'shift' - disables all plugins in the session.
Pulling out all plugins from the plugin folder and launching PT again.
Importing tracks into a new session a few at a time to see if any particular track is causing it.
Old 07-14-2022, 02:37 PM
Hello-
Unfortunately it didn't go well! Any different combination of bouncing tracks/re-uploading files hasn't made the problem go away and in fact things have gotten worse and now the graphics are glitchy everywhere. I've tried turning off permission for pro tools to communicate with avid and that also hasn't helped. Thinking of uninstalling and reinstalling pro tools because we can't think of any other solution.
Open Mix & Edit as Tabs in single window (Mac) Rooxii Pro Tools 2019 26 04-15-2024 02:22 PM
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Single button switches Mix to edit window? Tim Mayock Windows 3 08-04-2012 05:42 PM
Session Data/Mix Window/Edit Window gone?? 440Hz macOS 1 08-02-2011 03:44 PM
Fine adjust fader in edit window caput! command+adjust crizdee Pro Tools TDM Systems (Mac) 2 12-09-2008 03:55 PM
