Izotope RX audiosuite on pc: A sort of heads up
I have been forced to work from home this autumn, and use my home pc instead of the macs at work.
I pretty quickly started noticing how simple stuff was lagging in PT. Like creating a fade could take a second. Instead of instantaneous like I was used to. Or adjusting clipgain would create a black little box where the small volume fader should be. Simple stuff. The computer is plenty fast, and doing offline bounces of mixes was at least twice as fast as the mac minis at work. So it was not a question of the cpu not being fast enough. But then I noticed that sometimes it wasn't like that. After some testing it appears that the problem is caused by having several Izotope RX audiosauite windows open at the same time. I usually have connect, declicker, derustle and dialogue isolate open at the same time. Closing them one by one clearly showed that GUI response got better and better. This is not a problem with the other Audio suites I have tried. Weird, but there it is. Has anybody else seen this?
Newest Pro Tools on mac & pc. |
Re: Izotope RX audiosuite on pc: A sort of heads up
Win 10 PT 2020, Izotope audio suite send to Izotope RX Connect, many sub-windows open at once in RX. No issues here. Have you done all the standard optimizations to the PC?
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
There is something else wrong. RX audiosuite is not the issue. Do ALL standard optimizations; it's well documented.
Yes i have gone through the list.
Hyper threading is t.ex off, but doesn't really seem to matter. There is a difference between what I was describing and what you said. Maybe I misunderstood you, but: I have four or more of the RX suite of audio suites open at once. Including Connect. Audio suite, so "inside" protools. Not talking about how things are in RX stand alone. I also have many of them open in RX stand alone, but that does not seem to affect performance at all.
So I got help from Lars from Izotope
The fix was a classic. Delete the prefs. Doh. In my defense the installation was so new it shouldn't have been necessary yet. > SHOW HIDDEN FOLDERS FIRST > > Before trashing Pro Tools preferences, follow these steps to show > hidden folders: > > WINDOWS 8 & 10 > > * Click ‘VIEW’ in your File Explorer window, then check HIDDEN > ITEMS above Show/hide. > > TRASH PRO TOOLS PREFERENCES FOR WINDOWS > > PRO TOOLS 11, 12, AND 2018 > > * Close Pro Tools. > * Hold the WINDOWS key on your keyboard and press R. > * When the Run window appears, type %APPDATA% and press OK. > * Open the AVID folder, and delete the PRO TOOLS folder. > * Restart your computer and launch Pro Tools.
Have you seen this? Lots of new shortcuts for PT + iZotope integr., AudioSuite search | sigurdsivsko | Pro Tools 12 | 0 | 05-03-2017 11:20 PM |
Can't get rid of AudioSuite plugins (Izotope) | Juan Moore | Pro Tools 12 | 0 | 12-21-2016 03:58 PM |
8.0.4 kills Izotope RX (audiosuite) | lode | Post - Surround - Video | 14 | 07-05-2010 12:23 AM |
Bang Your Heads!!! Drum Heads Thread | Benoni | The Drum Room | 4 | 01-14-2010 03:37 AM |
iZotope Audiosuite and PT 7 | bugnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-16-2007 06:23 AM |
