Axiom25/m-tron Pro newbie
I've aquired the tools.
3 gig Imac/Pro tools LE 7.4/Axiom25/M-Tron Pro I think I've got it set up and connected right (USB). I can go to the plugin menu on an Instrument track and I can select M-tron Pro. The image of the M-tron pops up and I can click on the keys or press them on the controller and I can see them being pressed on the screen. That's where I'm stuck. I get no sound, no meter reading. nothing. I'm sure I'm supposed to be bussing the midi info somewhere to hear it, I just don't know where. Am I close? |
Re: Axiom25/m-tron Pro newbie
Bump
Am I not providing the right info? I'm trying to find the equivelent of a MIDI for idiots video walk through, but most of what I find is more of a "look at all the amazing things you can do once you get past the midiot stage" type of thing. From what I've learned, evidently there are so many different types of setups that its tough to find some one with a similar set of problems. At this point I'm just trying to find some basic info about what I should be doing to get my Axiom25 to make sounds in protools via the m-tron pro software. |
Have you record enabled the track?
Make a MIDI track. Leave it's input set to all. Set it's output to Mtron ch 1 Record enable the MIDI track. Play... What results do you get..?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Thanks!
Yes, I am in record mode. The simple step by step info provided is perfect. I've got all of that done and I'm getting levels in the midi channel. The sound is getting into the mac, just not out. Still getting no sound though. Aux channel insert, mtron pro. Problem with mbox2? USB is hooked up correctly. Checked preferences, sound working on youtube vids. ? |
Are you getting levels on the Aux track? What do you mean "sound is getting into the mac"? How do you know this?...
Your monitors need to be connected to the mbox. You can only hear ProTools audio through your Digidesign interface..
No levels in the Aux track, but I am getting levels in the midi track. Should I see the same readings in both?
Monitors are connected to the mbox, and I can open other PT sessions and listen to them. What I'm working in is a session set up just for learning midi, so there is no other audio tracks. By "into the mac" I mean when I play the Axiom25, I get a meter reading in the midi channel. |
Since your MIDI track is receiving MIDI and your Aux is not responding, then either the MIDI is not making it to the Mtron plugin, or Mtron is not configured correctly.. 1st thing to check is to make sure MIDI THRU is checked under the options menu.. I have a feeling this is your problem.. If not, on your MIDI track, when you click on the output selector, what are your options under M-tron?
Checked Options>Midi Thru and it's checked.
Midi Track Output selector Mtron Otions are: none Mtron Pro One>Channel 1 (checked) Predfined>mbox2 port 1 USB Axiom25 port 1 "Mtron is not configured correctly" Starting to seem possible, How would you check that? Edit: When I physically press keys on the Axiom25 I get a reading, but when I click on the keys on the image of the mtron, i see them being pressed, but get NO reading on the midi track. |
I have no idea what could be the problem with mtron as I don't have that plug. I would say try a different plug in, like Xpand, just to test the system. If Xpand works, all other things being equal, then you need to look into possible problems with Mtron.
Axiom25/PT 7.4 set up | Sonic Blue Meanie | MIDI | 0 | 03-27-2009 06:52 AM |
Structure/Axiom25 | cinvala | Virtual Instruments | 2 | 08-22-2008 03:45 PM |
Axiom25/Pro Tools/Trigger Pads/BFD | hearnie | MIDI | 6 | 06-04-2008 03:53 PM |
PT & Axiom25: nothing works, please help | Retinal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-01-2008 12:29 PM |
Axiom25- finally mine...one problem though | dubhausdisco1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-04-2006 07:47 AM |
