Old 10-21-2020, 06:47 PM
Default Artist Mix - Toggle Plugin Bypass when controls focused to encoders
Currently using an Artist Mix and iPad with Avid Control with the latest EuControl (20.6.1.3) on Mojave 10.14.6.
Is there any way to toggle a plugin's bypass when the controls are focused to the encoders or faders? This goes for EQ & Dyn modes, as well as Insert mode. It seems like the only way is to back out of the focus and go to Insert/Channel view so that the insert slots are visible on the encoder row, and use the small On button to toggle the plugin's bypass state.
This is a lot of backing in and out of the plugin focus just to A/B on and off for a plugin while tweaking.
On the iPad, I almost always have the automation soft keys page open when mixing and don't want to be jumping around to the Channel page all the time.
Scott Gatteño
Have option to spill plugin parameters on top encoders or Dock Sean Bombz Avid S1, S3, Dock and Control App 3 05-17-2019 08:44 AM
Is there a key command to toggle a plug in's bypass? Captain Audio Pro Tools TDM Systems (Mac) 2 04-30-2018 03:25 PM
Toggle bypass between 2 plugins? moshuajusic Pro Tools 12 4 09-30-2016 01:59 PM
red circles around plugin controls triple d2 Pro Tools 12 3 08-02-2016 02:27 PM
Can't see Channel Strip plugin controls (Track, Preset, Auto Map, Bypass, etc). DJ Hellfire macOS 9 05-09-2015 08:38 AM
