Old 08-09-2010, 05:43 PM
villagechurch villagechurch is offline
Default Sm81 and my 002 don't like each other?
Hello,
I shelled out money on a Shure sm81 for my acoustic recordings.
When I plug this in to my 002 pre amp I have to drive the gain over
3/4 of the way to get a good level.
What gives?
Anyone else have this issue on this mic, or an other?
Old 08-09-2010, 06:00 PM
flommer flommer is offline
Default Re: Sm81 and my 002 don't like each other?
Are you talking about acoustic guitar? If so, how close is the mic? How exactly are you mic'ing the guitar?
Do you have the pad on on the mic? On the 002?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-09-2010, 06:32 PM
Hello.
Guess I should have stated the settings.
On the mic itself I am using the 6 db roll off (makes no difference flat or rolled)
Pad is off.
002 pad is off.
I am mic'ing the guitar at a 45 degree angle pointed at the 12-14 fret about 5-6 inches away.
Old 08-09-2010, 06:54 PM
mcgwd mcgwd is offline
Is your phantom power on?
Mac Mini Pro 2.53 c2d | 4 GB Ram | OS X 10.6.4
DIGI 002R - Pro Tools 8.0.4 - latest plugins
OWC Mercury Elite w/ 80 GB WD 7200 rpm
Old 08-09-2010, 07:01 PM
Yes.
I also tested my Blue Blue Bird at the same gain setting...blew my cans right off my head...way to hot with the gain that high.
I think it might just be how this mic is.
Old 08-09-2010, 07:06 PM
Ok, was just checking, was the mic new or purchased used? Do you have another system to test it on?
Sounds like your 002r is working fine, I haven't used an 81 in awhile its a solid mic.Hopefully someone with this combo will stop on by.
Old 08-09-2010, 07:34 PM
Top Jimmy's Avatar
Originally Posted by villagechurch View Post
I shelled out money on a Shure sm81 for my acoustic recordings. When I plug this in to my 002 pre amp I have to drive the gain over 3/4 of the way to get a good level.
What gives?
Well, the Bluebird has a sensitivity of 27 mV/Pa while the SM81 has a sensitivity of 5.6 mV/PA.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 08-09-2010, 07:40 PM
This would make sense, and explain everything.
Sensitivity describes what I am trying to say.
IMO the sm81 is not very sensitive at all, very tight.
With these standard preamps it doesn't work well.
The amount of gain I am having to use is not fairing
well with the noise created.
Old 08-10-2010, 05:16 AM
BradLyons BradLyons is offline
Honestly, you should be looking at a better micpre to partner with any of these microphones. The pres on the 002 really aren't that good, in fact they are pretty harsh. The SM81 is actually a good mic, but you're not going to hear what it's really doing without upgrading your pre.
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 08-10-2010, 07:17 AM
Woodrow Woodrow is offline
I have had good luck with an 81 on acoustic guitar into my 002, but like was said before, a better pre might work, simply because more gain can be dialed up. If you've gotta crank the 002's gain, then you're going to get some silly noise. Someone else can give you reasons for why this happens.
I use a Solo 610 with the 81 and get good results.
Overhead Mics, earthworks, sm81 or AT3032 Dead River Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-24-2002 12:12 AM
Neumann U87 VS Shure SM81 stevalex316 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-09-2002 12:06 AM
Mics sm81 surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-17-2002 03:29 AM
