#31
Re: Eucon 20.5 Automation Lag
In regards to the Computer giving out DHCP addresses, I just want to clear up that its not(unless you have 3rd party DHCP Server software running), so people don't get confused. If there is no DHCP server(Router) on the network and the Ethernet port or Surface is set to DHCP (default) then the Ethernet adapter/Surface gives itself an IP address. This is always in the range 169.254.x.x and called Link Local. As this is always the same subnet everything can see each other. |
#32
That's correct Eddie. However I was having issues with link local dishing out IPs to wired tablets. Consoles had no problem. So I enabled the proper builtin macOS DHCP server (instructions here) and it has been working great since. Note you MUST change the IPs in this document so that they don't overlap your existing networks. |
#33
#34
it was written before: Quote:
#35
i have updated dock's firmware, and the situation is:
- still delayed auto write - huge lag on s3 displays - the layouts switch very quickly, but the displays stay frozen for many seconds, sometimes they even seem to never change so the layouts switching works. i just don't see the proper fader names. or eq parameters. congratulations on layout editing, finally. thanks |
#36
#37
I'm going to post a slightly older build of 20.5.0 for anyone brave who would like to test if its OK in this build. It was OK for beta testers. Please use the release installer to uninstall first and then install this build. Its Mac only and unsupported...other than from me on here. (You can always go back to the release)
It will work with the release Control App. 20.5.0.139 Please post your finding ASAP so we can figure this out and get a 20.6 release out. |
#38
i have installed the beta
at first it was even worse, then i restarted my s3 and euconand it is kind of better but still not perfect - the display lag is shorter, now it's like 2 seconds, sometimes 4 secs - after switching back from another application to protools there is like 30 seconds of total lack of contact, the s3 does not react - when it comes back to life the displays are frozen for another 30 second, but layout changes work - after that everything works with this 2-4 seconds display lag - however strange layout resets - all tracks change to auto assigned - happen from time to time (this i have never experienced before in any eucon version) |
#39
#40
the auto lag is still there
2018.7 Automation choppy with Eucon controller | SFXgeek | Artist Series | 11 | 03-18-2021 09:06 AM |
Logic 10.4.2 breaks Eucon automation modes. | robertg | Artist Series | 25 | 05-19-2019 04:59 PM |
Eucon/Artist Mix Trim Automation selection | HotRats_Reloded | Artist Series | 1 | 10-06-2018 05:29 AM |
automation mode glitch almost fixed in Eucon 3.4 ??? | yoerik | Avid S1, S3, Dock and Control App | 7 | 09-05-2016 07:15 AM |
PTHD 12.1 and EuCon automation | reichman | Artist Series | 1 | 07-09-2015 10:45 AM |
