waves diamond bundle problem
hello everyone, for a while I've had the waves diamond bundle version 3.2 installed on my computer and everything worked fine. I finally went out and upgraded to version 5.0 but I seem to have a problem. Some of the newer plug-ins like the L3, RenChannel, Linear Phase, EQ, X-Click, etc. all loaded fine and are visible as plug-ins in PT, but some of the plug-ins that were already on the computer that I know are included in the diamond bundle as well (Q8,10, RenEQ, Maxxbass, RCL, Enigma, Doppler, MondoMod, L1, C1, C4, and a couple others) aren't showing up in PT anymore. I installed everything properly, installed the wave shell, etc. Any advice on why so many of these plug-ins don't seem to be showing up?
Also, when it asked if I wanted to install the RTAS or VST versions I did both (since I have N-Track on my computer that I rarely use but figured why not). When I open N-track, ALL of the plug-ins show up; the ones that I already had plus the new ones, but not the case in PT. I need help Bret
PT LE v8.0 digi 002R digimax lt PowerPC G5 dual 2.0gz 7 gigs ram 2 TB HD Tannoy Monitors Yamaha NS-10 |
Re: waves diamond bundle problem
Try to go to:
c:\Program\Delade filer\Digidesign\DAE\DAE Prefs (it's pretty much the same in your lingo...) and force PTLE to do a new pref-file by deleting the one you have - this is a kind of "general fix" when it comes to matters like this - try it...
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
I tried and it didn't work. I opened up a song I had been working on and a few plug-ins weren't initialized since they were "not found in the plug-in folder" such as C1, C4, REQ, L1. I searched in my plug-ins folder and both WaveShell 5.0 files are installed but still only the newer plug-ins are showing up in pro tools and all of my previous ones are gone.
And still, they all show up in n-track. Could it be a faulty waveshell file or does anybody know what I can do to fix this? thank-you! bret
Make sure to delete your older waveshell files from this location:
C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins Also check this location to move and/or delete any improperly placed plugins to the new location listed above: C:\Program Files\Digidesign\DAE\Plug-Ins
Cavell Studios |
I just searched through the waves folder and there are .dll and .dll.rsr files. However, the ones that are .dll only that do not have a .dll.rsr file are the ones not showing up in pro tools (REQ, C1, C4, doppler, enigma, etc.) any ideas? Thank-you so much!
There should be nothing in the old location when you're through with it...and only one instance of the new waveshell in the common files location. Pro tools doesn't use .dll files for plugins...it uses *.dpm and *.dpm.rsr files.
Did you uninstall 3.2 prior to installing v5.0? Did you check to make sure everything uninstalled prior to installing the new version?
Cavell Studios |
i uninstalled everything and re-installed 5.0 and everything shows up and works beautifully! thank-you so much. I just assumed if you had a previous version of Waves on the computer it would auto update. Thank-you again!
Waves Diamond bundle | nrsv40 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-19-2008 11:15 AM |
Plug ins and WAVES Diamond bundle | dmartin714 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-09-2007 11:37 AM |
Ozone Vs. Waves Diamond Bundle | Johnny Cadelco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 23 | 05-29-2006 03:19 AM |
Waves Diamond bundle? | Pet Umbrella | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-07-2003 04:07 AM |
Waves Diamond Bundle | kmshroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 47 | 10-06-2003 11:12 AM |
