Old 12-01-2019, 02:10 PM
mushanga mushanga is offline
Default Cannot get rid of Pro Tools Aggregate I/O after uninstall of Pro Tools 9
I uninstalled Pro Tools 9.0.6 from my iMac Retina 2015 running macOS Mojave, removing what I thought were all the associated files. Yet despite this whenever I start up my Mac the audio output defaults to the Pro Tools Aggregate I/O and I cannot seem to permanently remove this from my system. I am using Logic and want to completely wipe all remains of Pro Tools. Is there an uninstaller that can do this? Why does this Aggregate I/O device keep reappearing?
Any help greatly appreciated!
Old 12-01-2019, 02:41 PM
Sardi Sardi is offline
Default Re: Cannot get rid of Pro Tools Aggregate I/O after uninstall of Pro Tools 9
Audio MIDI setup in Utilities folder in your Applications folder is where you can remove it.
Old 12-01-2019, 03:37 PM
Thanks for your suggestion - I have already tried this countless times. Makes no difference as the Pro Tools Aggregate I/O just gets repopulated in the list of devices in Audio MIDI setup after restarting the machine.
Old 12-01-2019, 03:59 PM
Hmmm... that’s curious.
If you don’t delete it, select a different interface for system audio in System Preferences, does it stick on reboot?
There should be no reason why it changes that setting on its own.
Old 12-02-2019, 08:29 AM
ChuckS ChuckS is offline
Do you have another version of PT installed? If so, every time you start that it will recreate the aggregate device.
PT 2019.10 DP 10.01 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1909)
PT 2019.10 DP 10.01 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 12-02-2019, 02:48 PM
Unfortunately it doesn't stick on reboot, instead it defaults to Internal Speakers and the Pro Tools Aggregate I/O still appears in the list. I have an RME Babyface Pro which is what I would like to be the default output.
Old 12-02-2019, 02:50 PM
Hi.. no - I only had Pro Tools 9.0.6 installed on the Mac. There must be some files hidden somewhere which weren't deleted which make the system think PT is still installed..?
Pro Tools Aggregate esmallwood Avid S1, S3, Dock and Control 5 05-12-2016 12:49 PM
Pro Tools Aggregate i/o storkindeutschland Pro Tools Express on Mac OS X 3 08-30-2014 09:30 AM
Pro Tools Aggregate I/O ggkarman macOS 24 09-10-2012 02:01 AM
Pro Tools Aggregate I/O GTBannah macOS 20 02-03-2012 01:50 AM
What is Pro Tools Aggregate? sixstrings22 macOS 1 10-21-2011 04:00 PM
