Old 12-26-2018, 04:39 PM
Top Jimmy's Avatar
Default Re: Exporting Audio (WAV) for a Mixer
Originally Posted by amagras View Post
Only solution is to print every track, this can be done in one pass if the track cou T is not too large when doubled.
Or bounce 1 track at a time
James Cadwallader
Old 12-26-2018, 04:43 PM
amagras amagras is offline
If there's processing in the Master Bus that might be necessary but I wouldn't recommend it if there's glue compression or shared parallel fx chains
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 12-28-2018, 06:31 PM
adamclairmont adamclairmont is offline
Hey, I haven't used the commit feature much but would this capture volume? I know it captures clip gain and inserts.
Old 12-29-2018, 06:38 AM
wwittman wwittman is offline
Why would a mixer actually want the volume and pan settings from the rough mix??
FWIW: If I had a session that was so locked in that I didn’t really want a mixer to have a completely new look at it (which begs the question as to why I would then be sending it out to be mixed by someone else) i would certainly search out someone working in pro tools so he/she could just open my existing session.
But when I get things to mix, I don’t really need volume or pan settings from the roughs.
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 12-29-2018, 07:22 AM
Emi's Avatar
Emi Emi is offline
If I were the mixer would definitely ask for the raw files. It’s like sending your mix to the mastering engineer maximized at 0dbFS.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
  #16
Old 12-29-2018, 09:08 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Yeah forget the pan and volume, that's all part of the mix. If the mixer wants to check your choices then he'll listen to your rough mix.
Check all the fades and crossfades on the tracks.
Check all edits such as comps, tuning, timing and such.
Commit any EQ, processing which is core to the sound of the track, especially amp simulations for guitar and bass. That said, err on the side of caution and don't box the mixer in with over processing.
Commit any virtual instruments.
Consolidate all tracks to the full length. For example, if the song is 3:48 then make sure the final audio tracks are all 3:48 in length.
Check with your mixer what file type is acceptable. 44.1/48 x 24 is pretty ubiquitous. So either convert from your consolidated tracks or else just send them a copy of the consolidated tracks.
Hope that helps.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
  #17
Old 12-30-2018, 09:31 AM
Not difficult at all: If you want all the automation/plugs/panning rendered, then select across all tracks and timeline and right-click to "commit" - choose "edit selection", check "consolidate clips", and render auto/panning if desired. After committing, select across the newly rendered tracks and shift-cmd-k to export desired clips to a new folder.
If you don't want panning/mono-to-stereo/auto/plugs, then just select across all tracks and timeline, shift-opt-3 to consolidate all edits, then shift-cmd-k to export the new files to a new folder.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Pro Tools 11 - Exporting Audio for a Mixer question TheEdster75 macOS 1 03-02-2018 07:23 PM
Eucon control over M-Audio Profire DSP Mixer/Focusrite DSP Mixer? finkbmx Artist Series 1 12-26-2010 12:11 AM
Exporting audio? yijvapar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-03-2009 04:56 AM
Exporting Audio, best way ?? shanabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2006 08:18 PM
exporting audio zook250 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-03-2005 05:58 AM
