Old 06-18-2019, 10:57 AM
Fritz Fritz is offline
Default Rogue Amoeba Loopback
Has anyone found a away to use Loopback so that you can use OSX BT in-ears at the same time as an Apollo?
So far, every method I've tried kills my HW insert or causes nasty distortion in the IEs.
PT aggregate w/UA, Loop & BT - no HW insert
Multi-Out w/UA, Loop & BT - no HW insert
Loopback - no HW insert
Tried to add PT, or UA and/or BT to the Loopback. Nada.
"Do not fear mistakes. There are none."
Miles Davis
Old 06-18-2019, 11:15 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Rogue Amoeba Loopback
Hi using it here with no problems . Im using a Focusrite Clarett 8 pre X . I remember i had to tweak the loopback interface digital wire conections in order to get everything working good . Not in front of my computer right now but i will check for you my settings . Just to clarify i don't use the BT as you want but maybe can help you out !
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 06-18-2019, 07:08 PM
thanks Jesus. Looking forward to some info.
Miles Davis
What is loopback? Popmeise Third Party Interfaces 4 12-15-2017 01:32 PM
Rogue message from protools on screen jamesleonard General Discussion 2 01-22-2014 06:28 AM
Anyone try unsupported Rogue Chassis w/ Pcix cards on MacPro ? KingFish Pro Tools TDM Systems (Mac) 0 11-05-2010 10:23 PM
Rogue Signal Generator groovilator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-28-2005 03:15 AM
Mbox with Audio Hijack Pro / Rogue Amoeba Chris Nelson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-19-2004 06:52 AM
