Option to decide the number of busses in buss menu
Hey guys, I have a very complex I/O setup for my mixes (as I'm sure a lot of you have) and pro tools' rigid bus menu hierarchy doesn't work for me...
(bus menu 1-128, 129-256, 257-384, etc... - screenshot attached) Is there any way to decide on new number clusters? That way, you could all your verbs on the first group, effects on the second, summing busses on the third, etc... Anyone?
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: Option to decide the number of busses in buss menu
In the I/O setup you can call the busses what you like. They don't have to be numbers.
So, you could call bus 1-2 'Verb Lexicon' bus 2-3 'Verb Softube' or whatever. You could have all your verbs (renamed) spread out over a group of closely related bus numbers, then do same for EQ, Compression, etc. and have the bus groups organised in any order Not sure if this is what you're asking.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
It splits the bus menus (when you assign a send in the mixer) to groups of 128. Those groups are too large, and I sometimes have to create 'filler' unused bussed just to 'skip' to the next group. Anyone else?
Couldn't you assign all your groups within the first 128 and delete what you don't need or delete what you don't need within each batch of 128?
I'll try to be clearer- I'd like to be able to decide on smaller numbers for bus menus. (should be user-definable) and that way, let's say you have 45 effect sends- those will be the first bus menu, (look at the screenshot) then distortion effect, then summing busses, etc... Right now we're bound to the arbitrary number of 128...
If you open Setup>IO and click the BUS tab, you can select all and delete paths, or select most(keep as many as you like) and delete the rest(select the buses you wish to delete). Ditto on naming to fit your needs. You can also create a new bus by using the "New Track" option(check youtube for some tutorials on using buses in pro tools)
Thanks Albee, that's what I was eluding to.
Basically, set it up however you like.
When you assign a send, if you have UNDER 128 busses, there will only be one menu for sends. If you have 129-256, you'll now have two menus for the busses and so on and so forth. Menu A, B, C, etc...
There is no way to do what you want that I know of. And I doubt other people think it’s even worth worrying about... as you can see by the replies here folks live fine by just naming the busses, other folks don’t seems worried by how those names are clustered in menus
Sent from my iPad using Tapatalk |
I've been trying to figure this one out as well.
Far as I can tell, there's no way around it. PT automatically creates a new bus "page" when it reaches each 128 limit. It would indeed be very cool to be able to assign busses to pages. |
Number of Busses | danyg | Pro Tools 12 | 4 | 01-11-2016 12:45 PM |
IO buss menu off the page | bcslaam | Pro Tools 11 | 9 | 06-03-2014 11:05 PM |
Number of busses? | audious | Pro Tools M-Powered (Mac) | 10 | 12-19-2010 04:52 PM |
No Busses on Input Menu? | Derek Hoiem | Pro Tools TDM Systems (Mac) | 1 | 11-22-2010 11:43 PM |
How to extend the number of busses in LE? | RiF | Tips & Tricks | 11 | 03-09-2010 06:55 AM |
