Old 12-15-2017, 11:17 AM
sixstrings22 sixstrings22 is offline
Default 003R as slave via MTC?
I am trying to transfer tracks from my old Roland 1604 > PT10 via 003R. I know the Roland can be the Master and deliver Midi Time Code but wonder if/ how I set up the 003R to be the slave.
Old 12-15-2017, 11:26 AM
EGS's Avatar
EGS EGS is offline
Default Re: 003R as slave via MTC?
Maybe this?
http://www.vsplanet.com/ubbthreads/u...&Number=806287
(It's been a long time, but I once slaved a Roland 1680 to 2" tape. Forgot how exactly...)
Click for audio/video demo
Click for resume
Old 12-15-2017, 12:20 PM
yes, the 1680 can be a very cooperative and capable machine. I found the data disc I'd saved the song to, and it booted up just like old times. My problem is I have more than 8 tracks on the song, so one pass for tracks 1-8 would be fine to transfer everything...but I need 9-16 as well, which means they won't be in sync unless i do something. I cannot see how the 003R can be switched to MTC and be the slave...but your link is a Great place to start, if I can find that page. Thanks!!
Old 12-16-2017, 08:14 AM
In the peripherals menu, the VS doesn't show up - as master or slave - depending on midi cable. It clearly has the drop down for 'MTC Reader' but it ain't reading. I may just try analogue transfer and see if I can line it up to my satisfaction.
Old 12-16-2017, 08:30 AM
EGS's Avatar
EGS EGS is offline
Read above link.
Click for resume
Old 12-18-2017, 09:50 AM
wow. it worked. Helps to read everything...Thank You. Now to figure out if I want to transfer each track by re-routing each one separately via digital outs (spdif) or analog 1-8/ 9-16. Anyway, I've got a few years worth of material - sandwiched between ADAT and Pro Tools...
Old 12-19-2017, 12:42 PM
EGS's Avatar
EGS EGS is offline
If you decide to use Roland analog outs, reduce the analog output level of the the Roland (somewhere in the main or perhaps utility page as I recall) by 3db. The Roland analog outputs distort VERY slightly ... if not reduced by 3db.
Click for resume
Digi 003r slave to Apollo twin? Rayray2000 Third Party Interfaces 2 10-09-2014 07:20 AM
Digi 002R as ADAT Slave to Digi 003R? Curdie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-01-2011 01:46 PM
003r in Slave mode with Projectmix MatthieuH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-06-2009 04:21 PM
Wordclock - 003R Master / Profire Slave - Syncing Issues blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-18-2007 05:23 PM
korg d1600 being slave a slave to pro tools sbag MIDI 0 04-12-2007 06:50 AM
