Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 03-18-2019, 12:12 AM
sonofglory sonofglory is offline
Default Avoiding cloud storage and security of cloud
When using pro tools first, how secure is the service, I often don’t feel comfortable with my work being on the cloud because I often worry about hacks and breeches, is it possible to go avoid transfer to the cloud, is it possible to use pro tools first and make small edits then export my audio before it transfers to the cloud, and if I use cloud storage are my files stored encrypted, and when sessions are deleted are they still stored on the server, are all my files 100 percent purged from the server?
Old 03-19-2019, 01:03 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Avoiding cloud storage and security of cloud
Pro Tools First is really meant to be used with a cloud account and I'm not sure you are going to get the answers you are looking for since only Avid knows how the server side of things works.
You can work offline on your projects and a local file cache is kept, but it is not designed as a personal repository and will most likely get messed up if you are moving files around.
Your best bet would be to go with the regular version of Pro Tools. There is a 30 trial version you can download and the rental plans aren't that expensive if you just wanted to see if the software meets your needs before deciding on a larger purchase.
Will
System Details
Cloud security and avoiding cloud sync sonofglory Pro Tools | Intro Discussion 4 05-26-2019 11:56 AM
AVID Cloud Storage jukbox Pro Tools 12 1 12-30-2016 12:01 AM
Cloud Security unkJE Avid Cloud Collaboration 1 03-30-2016 01:48 AM
Avid seems to cover the security issues with cloud sharing StefB Pro Tools 12 21 04-21-2015 06:12 PM
cloud storage? reichman Storage Subsystems 14 08-08-2012 01:10 PM
