Old 01-01-2014, 11:51 AM
Tony_Nailz Tony_Nailz is offline
Default Mackie MCU + XT midi drop out in Pro Tools HUI errors controller stop responding
Recently my Mackie MCU + MCU XT began exhibiting weird behavior in Pro Tools via HUI Mode. During a mix session or when recording, my controller will suddenly make a click noise, lock out & stop communicating with Pro Tools. Any & all feedback is welcome. Please help me sort this out, if anyone knows of a fix, please tell me. MCU is using firmware v2.1.2. these symptoms occur with both my MCU & the extender. I've tried calling the Mackie support hotline but they have been (mysteriously) closed for the past two weeks. & I am not having any luck finding anything on the web when googling these symptoms as I don't know the technical name of this issue.
I have created a youtube video of my issue so you guys can see my device in action when the issue occurs.
MY youtube video can be found here
Technical Notes:
*Both Devices are wired correctly
*Both Devices are connected to my MacPro via M-Audio MidiSport 4x4 (which is pro tools compatible)
*Both Devices are configured correctly in the Audio Midi Studio Setup
*The main controller is named HUI 1 & the Extender is named HUI 2
*Both devices are enabled in Midi Beat Clock & Midi Input Enable in Setup>Midi.
*Both Devices are setup correctly in Midi Controllers in Setup>Peripherals
*Midi Machine Control is not enabled under Machine Control in Peripherals setup
*Synchronization is not enabled for MTC Reader And Generator in Peripherals setup
See attached screenshot to see a picture of my current HUI device properties in Audio Midi Studio Setup.
If I'm not mistaken, I have everything setup right. I'm using Pro Tools 8.0.5 on OSX 10.6.8 on MacPro1,1 on woodcrest 2.66GHz Xeon Quad with 8gb ram. This is a dedicated machine, no additional programs are running, not using any third party plugins, only using PT factory plugins. I can get a stable recording nor mix session. fwiw, my OS & PT is only using 7% of my processor.
File Type: jpg Screen shot 2014-01-01 at 1.40.11 PM.jpg (63.8 KB, 0 views)
A. MacPro1,1 Intel Xeon 2.66GHz Quad Core (woodcrest), 8GB ram, OSX 10.6.8 250GB (Pro Tools 8.0.5), Digi 002r, 250GB Hard Drive (system)/ 250GB Hard Drive (recording) / 250GB Hard Drive (audio + sample bank), Mackie Control Universal + MCU XT (HUI mode), MPC 1000 & M-Audio Axiom 25 (primary rig)
B. MacBook4,1 2.1GHz Intel Core 2 Duo, 4GB, 150GB HDD+ 200GB EHDD, OSX 10.6.8, Mbox 2, Pro Tools LE 8.0.5 (mobile rig for editing)
*stability 1st*
Old 01-03-2014, 01:36 PM
Default Re: Mackie MCU + XT midi drop out in Pro Tools HUI errors controller stop responding
#wow!!! I guess when Avid announced EOSS for PT 8x, i guess that means #no forum support as well huh? If it wasn't for me experimenting with my settings until I #finally figured it out on my own, I'd be up the creek without a paddle.... smh
<rant>Since I finally upgraded my hardware & CPU, I probably need to jump to PT10, in order to get some love around here</rant>
*stability 1st*
Old 06-04-2014, 04:58 AM
cuttothebeat cuttothebeat is offline
I am having the same problem. I'm in PT 11 with 2x Mackie extenders. All works fine and then goes bad. I thought it was my midi interface going offline (because I do get some USB connectivity issues because I have so many devices connected), but, re-starting PT gets it going again so I don't think it is the interface.
Interestingly the Mackie's LCD screens still update and faders move with automation - I just can't SEND any info with them eg new fader moves, mutes, solos dont' work.
How did you fix?
Old 02-17-2015, 03:49 PM
Jslim Jslim is offline
im having a problem getting my mcu pro and ext to work using usb at all
let me know what you come up with
Old 02-23-2015, 07:56 PM
Got it to work
Old 02-23-2015, 07:58 PM
Hooking the main mcu pro to the audio interface and my mashine studio and fantom x6
Together in the midi chain
Using a Mackie HUI as a generic MIDI controller? turnstile MIDI 0 08-09-2011 04:29 PM
plug ins stop responding melvinR Pro Tools TDM Systems (Mac) 2 02-24-2011 01:53 AM
VI's stop responding? Kris75 Virtual Instruments 14 01-30-2009 09:15 AM
Protools 002 stop responding to PC Gilfigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-10-2005 09:30 PM
PT not responding to midi controller Brian21310 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-29-2005 01:34 PM
