VSS3 bypassing itself intermittently
I've been using VSS3 for about a month now and I'm really liking it but there is one annoying quirk I've been unable to pin down a cause for.
About 25% of the time when I open a project, vss3 doesn't work. The aux passes 100% dry audio. Simply bypassing and un-bypassing the plugin will make it work again. No crashes, just this weird intermittent bug. Where it becomes a problem is when I'm running off mixes of multiple projects, one after another I have to be vigilante in checking for this or I end up with a mix that is wacked...like an extra few db of DRY vocals outta nowhere...one day I'm going to miss it and accidentally send a messed up mix off to a client. Won't that be fun... Anyone else experience this? I'm running OS 10.4.11 PT 7.4cs2 on a macpro quad 2.6 Thanks, -Zak |
Re: VSS3 bypassing itself intermittently
Chris
Now why didn't I think of that...?
I have a feeling it'll work, I'll try it and report back... Thanks! |
No problem here.
D-Control ES goes offline intermittently. | [email protected] | ICON & C|24 | 9 | 10-07-2010 12:26 PM |
PRO TOOLS SCREEN FREEZES INTERMITTENTLY! | Torchlight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-15-2006 10:22 PM |
Intermittently dropping in to record on playback | tinfoil | Pro Tools TDM Systems (Mac) | 0 | 05-12-2006 02:15 AM |
Digi 001 Hardware Intermittently Found | BASSKLEFF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-26-2004 11:59 PM |
Hardware not recognized, intermittently | dkapz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-31-2000 02:15 PM |
