Old 01-24-2024, 03:04 PM
Mike Borok Mike Borok is offline
Default Space Bar moves cursor
This just started happening, and I wonder if it's a setting that got changed, or some glitch in my setup. Normally, space bar starts and stops transport, but doesn't change the cursor start position. Now intermittently when I use space bar to stop, the cursor moves to the spot where playing stopped. And if I select a section, spacebar seems to unselect it.
Any ideas? Thanks.
Mike
003 Factory PT LE 7.4
Intel Core 2 CPU 6320 @ 1.86GHz
Gigabyte Technology G33M-S2H
2GB DDR2-SDRAM
XP Home 5.01.2600 (Service Pack 2)
Old 01-24-2024, 04:03 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Space Bar moves cursor
Hit the "N" key by mistake per chance?
It toggles "Insertion Follows Playback" and there is a "button" for same under the Supertool.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-26-2024, 11:26 AM
Changing the value of Play Start Marker Follows Timeline Selection (toggle N key) didn't make a difference - I enabled and disabled this and it didn't change the behavior.
To recap: I position the cursor, hit play, and then regardless of whether I hit spacebar or the stop button, the cursor moves to the place where playback stopped. I swear I don't remember this happening before. Also, if I highlight a region, start playing that region and then hit stop/spacebar, the region selection disappears.
2GB DDR2-SDRAM
Old 01-26-2024, 11:43 AM
its2loud its2loud is offline
Hitting the 'N' key is not going to change this unless you have Keyboard Focus enabled. You need to go up to the Option menu and uncheck "insertion Follows Playback" Do a Google search or You Tube search for this feature in Pro Tools if you're not familiar with it.
Old 01-26-2024, 12:45 PM
The Weed's Avatar
My bad, I assumed most people have Commands Focus enabled, although I did also mention a "button" that toggles Insertion Follows Playback.
SonoBus
Old 01-28-2024, 11:49 AM
I found the setting that was causing the problem. Setup>Preferences>Operation
Timeline Insertion/Play Start Marker Follows Playback
was checked. I unchecked this and the cursor stopped moving as described (which is what I wanted). I don't know what the keyboard shortcut for this is, or how I might have hit it...
2GB DDR2-SDRAM
cursor, space bar and scrolling behaviour jazubon Pro Tools 12 9 04-29-2018 08:45 PM
cursor moves unsteadily banjo71 Pro Tools M-Powered (Win) 1 04-03-2010 07:34 PM
Cursor moves buy itself ONLY in PT! quangaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-30-2009 11:44 AM
Cursor start position moves after playback... WATYF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-12-2005 10:26 PM
Pressing down arrow moves cursor to start guitarmongoose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-05-2005 09:47 AM
