Old 02-04-2018, 12:13 PM
Calex88 Calex88 is offline
Default Pro Tools will not Open a Session
One last problem.
I updated to PT 2018 and now when I go to one particular session, it simply will not open. I used to get an error, but it is not doing that anymore.
Just a small window flashes, but much too quickly to make it out and then nothing.
I have gone through optimization and can't seem to find any related posts.
Samsung ATIV Book 4 Windows 10 latest update Focusrite Scarlett Solo
Old 02-04-2018, 12:22 PM
Drew Mazurek's Avatar
Default Re: Pro Tools will not Open a Session
try opening with no plugins active. (hold shift while clicking open)
Or make a new session and use Import Session Data to bring in your tracks a few at a time until you find the culprit.
www.drewmazurek.com
Old 02-04-2018, 12:34 PM
Thanks, I will look into that. Looks like my pic with the error did load the first time.
I hope this helps.
Old 02-04-2018, 12:48 PM
None of these will open.
Old 02-04-2018, 01:19 PM
jjnssn jjnssn is offline
Do you have Waves plugins in your session? Plugins that use their Artist Dlls? If you go into events and look at the error look at the faulting module. Paste your results here.
Old 02-04-2018, 02:17 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I'm on windows 7 so it may not help but after I updated to 2018 I had to re-install all my Waves plugins to get Pro Tools to start up properly. Try putting the waveshells in Unused plugin folder and opening see if that works. If it does than try the reinstall.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 02-04-2018, 05:22 PM
I don't have the waves plugins. It was a short track so I decided to redo it.
It is not quite the same, so if anyone figures it out, let me know.
Old 02-05-2018, 12:47 AM
did you try these?
www.drewmazurek.com
Old 02-05-2018, 07:14 AM
did you try these?
I did and I tried twice to post that nothing was opening, but they never made it up.
I have attached the pic of what I am trying to open.
Old 02-05-2018, 07:21 AM
What happens when you create a new session and try to import a track from one of those sessions?
www.drewmazurek.com
Will Pro Tools 9 session open in 11? Natanel Arnson Windows 3 10-22-2014 05:41 PM
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 07:53 AM
Pro Tools 8 crashing when I try to open a session or start a new session AbstractHabitat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-25-2012 04:58 AM
pro tools 7.0 won't open session help please Malick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-09-2008 04:02 PM
I can't open my pro tools session aldeaproducciones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-09-2005 09:03 PM
