Old 02-17-2016, 08:10 AM
Blobsie Blobsie is offline
Default 11R Reamping using Apollo as interface and Studio One
Hi
Wondered if someone could help a newbie out.
I have been given a 11r to play with specifically to do some reamping.
My main interface is a Apollo Quad. I have connected the 11r to the apollo via Spdif.
In studio 1 i have routed the single out to the spider l channel and in the new track routed the in from Spdif R
On the 11 rack i have set rig input to Re-Amp and the Digital output to Split in/ out.
I can see signal going out but i can hear any signal coming back!
Any assistance gratefully received
Old 02-17-2016, 08:55 AM
Default Re: 11R Reamping using Apollo as interface and Studio One
Originally Posted by Blobsie View Post
Hi
Well this one is easy... You don't set the rig input to reamp... doing that connects the rig input to a specific input IO channel when used as a USB interface. You are not using the Eleven Rack as an interface here so that's the wrong approach, you need to set the Rig input to S/PDIF R.... where your dry signal is.
You don't need to set the S/PDIF output to split in/out since you already have the dry input, but if you just want to pull off mono output it wont' hurt.
Old 02-17-2016, 09:41 AM
Hi Darryl
Thanks for this
Ive now got the rig input to Spdif R
Digital Output to DAW
my signal is routed out to Sdif R and in from Sdif R (is this correct??)
Still nothing!
Old 02-17-2016, 09:58 AM
Use the meters on the front panel display (far right or the rig view) to see if you have signals anywhere.
Old 02-17-2016, 10:59 AM
Dear Darryl
Appreciate your help so far
i can't see any meters or anything in the 11r editor.....
Sorry!
Old 02-17-2016, 11:50 AM
In the Eleven Rack front panel, the actual box, not the editor GUI, scroll to the far right items in the display, and/or look up meters in the Eleven Rack User Guide.
You also should be able to help debug this by connecting headphones to the Eleven Rack and getting a wet signal to play back there when you are driving the S/PDIF input from your DAW. Just outputting to headphones/main output, not even trying to record.
Common errors include not cross-connecting S/PDIF Out to In between boxes. Wrong sample rates between the ER and other box, wrong clocking setup (but you'd still hear stuff).
Old 02-18-2016, 10:57 AM
Really helpful - will try again this evening
Old 02-19-2016, 04:47 AM
Dear Darryl All Sorted!
Note to self - turn on 11R before tuning on computer!
Ive got the Rig input set to Digital R, output of track set to digital R then on new track input Digital R output main.
then 11r output set to rig outputs and hey presto all sorted!!
Thanks for your assistance much appreciated!
Old 02-19-2016, 11:02 AM
You should not have to (especially when it's not the interface), but if that made the difference great!
If I could wave a wand there is a few things I'd do to an Eleven Rack Mk II on the usability side. One would be to give the option of concurrent amp and amp+cab output for live players. The ability to manually disable internal monitoring (for non-Pro Tools DAWS like you are using). I might even add an front panel LED to show when the guitar input is selected as rig input ('cos we all make that mistake). Another one would be to change around menus so things like meters are more obvious. Oh and add ADAT/SMUX In/Out. And dual direct connect expression peals (esp. for allowing a simple foot switch + one pedal). None of which will happen... sigh.
Old 09-15-2017, 03:19 PM
hacha hacha is offline
Hi
Sorry...but how to connect the eleven to the uad twin interface? if this does not have spdif ..... thanks
UA Apollo Interface Issue adam79 Third Party Interfaces 2 02-04-2016 06:53 PM
UA Apollo Quad - FW interface YYR123 Buy & Sell 13 12-07-2015 09:31 PM
UAD Apollo Twin Solo Interface & Pro Tools briaboy Third Party Interfaces 12 05-04-2015 10:06 AM
Issues After Updating UA Apollo Interface viktor99 Pro Tools 10 0 11-03-2013 10:36 PM
PT11 compatible UA Apollo interface? djkikis macOS 4 07-05-2013 07:44 PM
