Sampler
I want a fully functional software sampler that works with PT 7.4 running on a dual 2.3GHz on Tiger. Is that at all possible these days?
Re: Sampler
Fairlight CMI.
Aaron Mulqueen - 001 HD Native |
Re: Sampler
I'd rather use my AKAI S5000 if it comes to that.
Re: Sampler
I've now watched all 6 parts of the Structure videos, and I like it. Clean interface, easy to use and nice features. Does it work? All the fuzz that's been on these forums seem to indicate that it doesn't work properly. What's your take on this? I see there's been released an update recently - did that remedy the problem(s)?
Re: Sampler
on my iMac c2d 3,06/4gb/10.6 it ran good even before the latest update.
If structure works in 7.4 (try free first) than I totally recommend it. With all the Kontakt and EXS librarys out there, + the stuff from the Air USers blog and even more, it`s a great sampler. 1.0.3 made it work in Snow Leopard (not an issue for you I see,) and the latest update was to fix EXS import. I know we are running different OS and PT versions. But if it works for me on 8.0.3, it should run great on the more stable 7.4. Enig? I`ve been running 5 separate midi channels of 5 different patches at once and it`s light on the cpu, even when running from boot disk. (Just because I didn`t bother with my external drive when I was trying out new patches. So i recoment it, IF it is available for 7,4. Snarf/Stian
Stian Sylta Producer/Songwriter/Musician Sons Of Vanity on iTunes/Spotify MacBook Pro i7/Apogee One/Duet/ElevenR/Pro Tools 12 Preamps from UA, Mackie and Avid. Listening through Dynaudio, Genelec and ADAM |
Re: Sampler
I've used Structure for the last two years on Mac and Win with few complaints. I now have the new build which definitely solved some outstanding issues and introduced a few "new" sounds. I did not have the need to import EXS, so I was not affected by a lot of the drama surrounding this VI.
If you are a big preset-playback cat and have a large library with several different formats I would currently recommend Kontakt, to be honest. They've had their own share of issues in the past, but are currently a solid, multiformat player in the sampler field. However, if you're an AIR fan and going to use the VI for original sound creation with some patch playback, I think Structure works just fine, and sounds fantastic. Multiformat works fine now and you can also utilize the AIR Users Blog for some amazing patches and great videos. Russ is top notch. Since you're basically a new buyer, you've come to this at a unique time. The whole tale surrounding Structure in the past was certainly a mess. There were several valid issues and points made by some outstanding hobos, and there were also a lot of people in our community acting like idiots and making us all look quite unprofessional. So take the DUC for what it is. Whichever VI you choose, good luck. Make some awesome music!
--------------------- Darth Hobo, Dark Lord of the Synth ========= |
Re: Sampler
Different OS and an older version of PT could potentially be bad news. Quote:
After my horrible experience with NI and Kontakt, I gave up on samplers totally. I was curious about Structure when it first came out, and now I seem to be kinda pushed into sampling again due to client requests. Thanks for your input, guys. I appreciate it.
Re: Sampler
Oh no. From the compatibility pages:
"Qualified Intel-based Mac running Mac OS X 10.5.x or 10.6.x (Intel only) Pro Tools|HD, Pro Tools LE, or Pro Tools M-Powered system running Pro Tools 8.0 or higher software" Fudge!
Re: Sampler
http://duc.digidesign.com/showthread.php?t=275294
There's 2 different version, and in the sticky I've linked to the 1.0.5 version seems to be compatible with my system? If yes, is it possible to demo and buy the older version?
Re: Sampler
EXS import was only a supporting actor in the drama. Small role. A cameo.
Need a sampler | GothicV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-22-2009 07:27 AM |
Sampler | Studio Studio | Virtual Instruments | 5 | 02-18-2009 06:09 AM |
So, which sampler? | Allan Speers | Pro Tools TDM Systems (Mac) | 7 | 10-03-2003 02:16 AM |
Sampler/Drum Sampler sw.....What's best? | Thundernut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-09-2003 09:26 AM |
yo, what is a sampler anyway? | matthewinphilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-31-2000 12:32 AM |
