AMD 64X2 - MSI K9VGM - 2GB DDR2 800MHz - BUFFER ERRORS!
I've had a few questions answered, THANX!, but still having problems with buffering.
(I'll delete my other posts on this right now) PTLE7.1 002 Rack Control 24 Computer Configuration Sandra Report listed below. COPNSTANT BUFFER ERRORS!!! No matter how I configure the settings! I've installed the Digi recommended AMD Optimizer, and Microsoft Dual CPU Hotfix Installed the Digi recommended ADS Tech PYRO 64 PCI Card (Firewire adapter) Can't get it to play for more than 1 Minute without Buffer conflict errors... SiSoftware Sandra System Host Name : SHORTY User : John Workgroup : CONTROL 24 Processor Model : AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ Speed : 2.20GHz Model Number : 4200 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Low Power, Dual-Core Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Platform Compliance : AMD LIVE! Bus(es) : ISA AGP PCI PCIe USB FireWire/1394 MP Support : 1 Processor(s) MP APIC : No System BIOS : Phoenix Technologies, LTD 6.00 PG System : MICRO-STAR INTERNATIONAL CO., LTD MS-7253 Mainboard : MICRO-STAR INTERNATIONAL CO., LTD MS-7253 Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : VIA Technologies Inc K8M890CE Host Bridge Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Total Memory : 2GB DDR2-SDRAM Memory Bus Speed : 2x 366MHz (732MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : RADEON X700 Series Adapter : RADEON X700 Series Secondary Physical Storage Devices Hard Disk : Addonics CF (64MB) Hard Disk : SAMSUNG SP2504C (233GB) Hard Disk : WDC WD800JD-60JRA0 (75GB) Hard Disk : Ut161 USB2FlashStorage USB Device CD-ROM/DVD : IN-CDRW DX-CDRW (CD 52X Rd, 52X Wr) CD-ROM/DVD : TSSTcorp CD/DVDW SH-S182M (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) Logical Storage Devices Removable Drive (G:) : N/A Hard Disk (C:) : 75GB (65GB, 87% Free Space) (NTFS) New Volume (D:) : 233GB (163GB, 70% Free Space) (NTFS) CD-ROM/DVD (E:) : N/A CD-ROM/DVD (F:) : N/A Removable Drive (H:) : 490MB (412MB, 84% Free Space) (FAT) Peripherals Serial/Parallel Port(s) : 2 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA USB Enhanced Host Controller USB Controller/Hub : ATI Remote Wonder Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : PS/2 Compatible Mouse Printers and Faxes Model : EPSON Stylus Photo R200 Series Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Adapter : VIA Compatable Fast Ethernet Adapter Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
Re: AMD 64X2 - MSI K9VGM - 2GB DDR2 800MHz - BUFFER ERRORS!
Also, could you please list your installed plugins, including version numbers? (That's "installed", not "used in session"). Any other audio programs installed? Which ones and what versions? Could you also detail the session(s) where you are experiencing this problem? How many tracks, what plugins you are using, sample rate, bit depth, etc etc? We usually like to leave other posts up so they can help other people who might be having similar problems.
Really? A Card Reader and a USB Driver/Device?
Ok... will try!! Here's the info requested. Waves Diamond Bundle v5.0 and the L3's v5.2 Antares Vocal Kit v5.0 A slew of other VST plugins that are obviously not used in PT (Licensed, not cracked! We installed them with the license from our large facility) None in use in the session. I made a 4 Track beat off the MP and Motif, Mo Phatt, etc, and dumped it in, copying it out to 4 minutes or so. Another session does the same thing, with a single audio track at 24 bit 44.1 no plugs.
Also, please list the error numbers in the messages you're getting.
My bad....
Error #'s 9129, 9092, 6085, and one more that ells me to try disconnecting any other firewire devices on that bus.... 002 Rack is the only thing on it. OTHER SOFTWARE: Sonar 6 Producer Edition Reason 3.0 CD Architect 5.0 Photoshop CS2 Other little stuff non music related, printer drivers, ATI Catalyst software for Vid Card, etc. I think Nero is on there for my DVD Burner, ATI's stupid media player, Windows media player... Can't think of anything else of significance.
Doesn't the MSI K9VGM have onboard video? That could be a problem. You're using the Samsung SATA drive for sessions, correct?
No, haven't installed the PT7 Patch - will try
Will update PACE Drivers tonight Yes - using the Samsung for Audio Yes, has onboard Video- Can this be turned off? I am using an ATI X700 Pro PCIe card (2456 MB?) I Also noticed that 64MB shared is set up in the BIOS, can I set it to NONE?
If you can turn off the 64MB shared in the BIOS, I would try that.
Picky Picky....
I appreciate the info. I'll try these additional things this evening and post my results back on this thread. I'll try to remember everything I've done and list them in succession so as to provide a detailed log of my troubleshooting procedures. Perhaps that will also help other users, and if I'm still down, we'll all have a good idea where we're at. (I also just realized that I installed the Windows XP Dual Core Hotfix, but didn't complete the alterations to the "regedit"... maybe that's part of it too.) Thanx Again
Hey... Where the crap do I find the PACE Drivers? For LE 7.1
What are they? I can't find them on Digi's site. Their site's kinda screwy. Thanx!
6086, buffer underflow, hw buffer size and other errors on i7 | rhythmtechnologies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-30-2009 08:36 AM |
2GB DDR2 or 3GB DDR ? | MarkusB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 04-16-2007 10:44 PM |
HW Buffer errors and Mass Confusion! 9093 Errors!! | guitarlancer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-08-2007 10:38 AM |
Buffer Errors / Buffer Problems? | freezegelman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-28-2006 11:50 AM |
My 800MHz PIII won't run at buffer size 128.... | merwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-06-2000 08:32 AM |
