Hi, I am trying to sync my Mac Digi 002R/ProTools LE with Acid Pro 5.0c on my PC. Does Protools LE generate MTC, or Midi Beat Clock ? Acid Pro seems to want MTC only, and perhaps this is why it's not working.. Thanks
pt does not generate mtc or beat clock.
i sync my pt rig with my mpc 2000 via mtc. the 2000 generats mtc. also i can control protools from the 2000 thru mmc(midi machin control). you will probaly need a smpte box that will lock up your set up. good luck! one |
![]() Quote:
rock sdf |
SDF...Beautiful, thanks..the Apple key/#2 settings are what I needed. Thanks again..
Happy to help...
sdf |
About beat clock, do you know if it's possible to sync ProTools to incoming Beat Clock data?
Sam Ejnes Mix Technician, Freelance Sound Editor/Re-recording Mixer samejnes.com | IMDb | Analog Jitter rMacBook Pro 2.2 gHz Core i7, 10.10.3 16 GB RAM MOTU 828mkII, PT 12.1 HD Axiom 61, 2xArtist Mix |
![]() Quote:
sdf |
I would also like to know if Pro Tools can chase MIDI Beat Clock. I am using DP for MIDI and PT for audio and would like to sync the tempos using MIDI Beat Clock while using MMC & MTC for syncing transports.
Digi? |
Pro Tools Slaved by Midi Time Code or Midi Beat Clock | DarylBham | MIDI | 5 | 06-14-2009 02:55 PM |
is there latency when using midi time code or midi clock(im still new at this) | Cali Hendrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-15-2003 11:18 AM |
is there latency using midi time code or midi clock(im new) | Cali Hendrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-13-2003 05:50 PM |
is there latency using midi time code or midi clock(im new) | Cali Hendrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-13-2003 03:32 PM |
MIDI Clock vs. MIDI Time Code | thopman | Tips & Tricks | 2 | 06-20-2001 06:01 AM |
