Old 11-12-2010, 05:50 AM
bobbyskeg bobbyskeg is offline
Default Strike "not enough physical memory, select smaller size" error
I just installed Strike through the Instrument Expansion pack and it won't work at all. When it loads up it only lets me audition the presets, but when I come to loading them it comes up with the error "not enough physical memory" and then nothing happens. Any idea what's causing this and/or how to fix it.
Thanks
Pro Tools 8.1 HD3
Intel i7 980x 3.33Ghz 6core
12 GB DDR ram
Old 11-12-2010, 09:26 AM
otobot otobot is offline
Default Re: Strike "not enough physical memory, select smaller size" error
I had this happen the last time I loaded Strike, but I also had several other VI's loaded. So I wondered like "that must be a big kit..." and thought it was because of low available RAM (I have 3.25 GB available).
Now that I think about it, either there's something wrong with Strike (bug/shmug) or it's a serious RAM-hog.
I will try again this WE and let you know..
Old 11-12-2010, 10:21 AM
After installing PTIEP did you delete all the Prefs and repair permissions?
Aaron Mulqueen - 001 HD Native
Old 11-12-2010, 10:36 AM
I didn't do that no. How do I do this and what effect does it have?
Thanks
Old 11-12-2010, 10:38 AM
I thought about the momeory hog thing and opened it in a brand new session with nothing other than a VI track and the one Strike plugin. Plus with 12GB RAM I'm sure the memory is'nt actually the problem, thanks for the input though
Old 11-12-2010, 11:06 AM
I've misread your question, thinking you were talking about not enough DAE memory. Ummm... Pro Tools, currently, has a 4 GB cap as it is still only a 32 - bit programme running in a 64 - bit Operating System. And yes, if you do not have Strike content loading size restricted, you are going to be presented with that content error. Try 800-400 MB.
Old 11-14-2010, 12:51 PM
All seems to be working now randomly, did a few restarts n it started working. Some wierd teething issues I guess. Thanks though
Old 11-14-2010, 06:00 PM
What is your Strike Content Size setting?
"Can't write to location" error, bad memory? digidesigner Pro Tools TDM Systems (Win) 3 11-02-2011 10:52 AM
Once again "Content Not Found error with Strike" rockme Virtual Instruments 13 11-11-2010 10:27 AM
Errors - 7.3.1 crash after DAE error and "Could not allocate DFD memory" GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-11-2009 08:01 AM
error message "increase buffer size" PLEASE HELP rebirth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-04-2009 01:21 PM
Pro Tools 8 crashes "out of memory" error jflowers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-31-2008 09:40 AM
