Old 04-12-2021, 04:56 AM
Default Re: How to control Soundtoys parameters via MIDI?
Originally Posted by Sardi View Post
Yeah, from memory they don’t.
I use Eucon to control them, so it’s been a while since I tried MIDI, but IIRC, they don’t work via MIDI in PT.
It's not just PT but Digital Performer that you can't MIDI learn Soundtoys controls. And even if you could why would you want to be restricted to the 128 steps of MIDI anyways? I seem to remember a recent thread here where somebody asked about doing MIDI controls of plugin parameters; I know it didn't turn out quite like what the op wanted.
edit for additional:
Here's the thread I'm talking about https://duc.avid.com/showthread.php?...27#post2591627
Old 04-12-2021, 05:31 AM
Sardi Sardi is offline
Well you would use it if you had no other option. Course resolution is better than no resolution.
Old 04-13-2021, 04:22 AM
clausiii's Avatar
clausiii clausiii is offline
here some screenshots how the plugin window changes once you enable a midi controller.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 03-05-2022, 10:53 AM
levelaudio levelaudio is offline
This only seems to work when the controller is set up as m-audio keyboard. But if I add the nanoKONTROL2 the the way you've shown in your screenshots, I still can't seem to get it to work. And I'm curious why you have IAC ports set up for the receive from and send to, and if you've actually successfully used the nanoKONTROL2 this way and mapped its knobs/sliders to soundtoys plugin parameters.
Control Plug-In Parameters with a MIDI control surface b1daly Tips & Tricks 8 03-26-2023 09:29 AM
Do you think we'll ever see generic MIDI Control of plug-in parameters? weezul Pro Tools 12 17 02-27-2016 05:21 AM
Midi Control over Plug-in parameters help... breaktheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-11-2010 03:55 PM
Control Reason parameters via PT MIDI automation? Pulque 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-23-2004 06:36 PM
control plug parameters via MIDI Slink General Discussion 0 05-17-2003 07:47 AM
