Old 05-12-2014, 12:55 PM
makaroni's Avatar
makaroni makaroni is offline
Default Error -9169
Error trying to communicate with the DigiShoeTool. This could indicate a permission problem with the installation. Try a clean reinstall..
i already do that, works for a few then again….running 10.3.9 HD, clean install and 10.8.5!
Old 05-12-2014, 05:50 PM
Chief Technician Chief Technician is offline
Question Re: Error -9169
If you launch Terminal (/Applications/Utilities) and type cd /Library/Application Support/Avid/Pro Tools then press return, followed by ls -la and press return, what text is displayed at the far left of the line that has DigiShoeTool?
On my system it's -r-sr-xr-x, which translates to owner (root) can read with set user ID, group (admin) can read and execute, and everyone else can read and execute.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 09-18-2018, 08:36 AM
KingTor KingTor is offline
Default Re: Error -9169
I'm reinstalling Pro Tools 10 on an older computer right now and ran into this error after a clean install. I tried the above and got the same results as yours.
-r-sr-xr-x 1 root admin 21824 Jan 28 2015 DigiShoeTool
Any further advice?
P.S. for anyone else trying this, with a director name with spaces, you need to use cd '/Library/Application Support/Avid/Pro Tools' in the command line (with the apostrophes enclosing the path).
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 09-18-2018, 03:40 PM
BTW, a clean uninstall and a fresh install did work in my case. Strange, but true.
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 Karma180 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2011 07:46 PM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O booyaaslam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-04-2002 01:55 AM
