Old 05-11-2020, 09:50 AM
shaft shaft is offline
Default shortcuts for selecting audio clips
I know that you can use the p and ; to move your selection up and down vertically, but is there a shortcut to move the section to the next clip horizontally?
I am editing some percussion parts that I have sliced up at the transients and it would allow me to work much faster
Old 05-11-2020, 01:56 PM
Default Re: shortcuts for selecting audio clips
The Tab key(assuming Tab to Transient is OFF) will advance to the next clip edge(end of the clip the cursor is in, then Start of next clip)
Old 05-11-2020, 02:11 PM
Thanks for the response. I know that you can use the tab to go to the next clip but I want to select that clip without having to use the mouse.
Old 05-11-2020, 10:49 PM
Oliver M Oliver M is online now
Tab key, then shift-tab key. Assuming the clip contains no sync point, else it would be tab key then shift-tab key twice.
Old 05-12-2020, 08:13 AM
Ctrl-Tab (Mac) will select the next clip. If there is a fade, it will only select the fade. Ctrl-Shift-Tab should then select the rest of the clip. You might need to Ctrl-Shift-Tab a few times if there is a fade at top and tail.
Scott Gatteño
Old 05-13-2020, 10:22 AM
Thanks! Those both work. Thats what i was looking for
Old 05-13-2020, 10:58 AM
tmuzik tmuzik is offline
In case you have not come across this yet.
http://www.protoolskeyboardshortcuts...ard-shortcuts/
Who is John Galt?
Selecting range of clips MusicMadness Pro Tools 2018 5 05-31-2018 02:13 PM
HELP - Selecting UNUSED audio to delete... Darryl Duncan Pro Tools 12 7 03-30-2017 04:28 AM
Selecting Clips vertically with Keyboard robbieklein Tips & Tricks 3 10-29-2016 02:29 PM
Clips Bin shortcuts gguardia macOS 3 08-26-2015 12:20 PM
Selecting multiple muted clips Manu101 Pro Tools 10 2 01-23-2013 12:55 PM
