Clip List question
Hi, apologies if this is really basic but I cannot figure out...
Why are all audio tracks listed in the Clip List (far right of edit window) appearing with the SAMPLE based indicator (round blue symbol) instead of the TICK based indicator (green triangle)? I have tracks selected to be TICK based when I create them, and the TICK symbol appears under the track name in the edit window. Why then are clips created on these tracks appearing as SAMPLE based in the CLIP list? Thanks for any insight... |
Re: Clip List question
Audio tracks are on the left side, audio files "clips" are on the right
the sample icon in the Clip List denotes the clip between an Audio file clip and a Midi file clip or something like that
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
thank you for the reply, maybe I wasn't clear on the question:
I understand that that tracks in the edit window can be sample based OR tick based. My question is why do ALL tracks appear in the CLIP LIST (the window to the right side of the edit window) as SAMPLE BASED (with the little blue "clock" icon)...as opposed to tick based tracks appearing as tick based in the clip list. I did notice that when I enable elastic audio on a track, the clip list changes to indicate tick based...but when a NEW track is recorded (as a tick based track) it still appears in the clip list as sample based. Anyone? |
It really helps to use the right nomenclature. A track is not recorded, audio is recorded on a track.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thanks for the reply. Yes "show auto-created" is selected. I do see sample based file clips and tick based clips.
Allow me to clarify: My question is why do clips automatically appears as SAMPLE based in the clip list (blue clock) rather than as TICK based (green triangle)? - I understand that audio is recorded onto tracks. What I was referring to was that I have the preference set for "new tracks default to tick based". Why, when AUDIO is recorded onto a tick-based track, does the CLIP corresponding to that audio appear in the CLIP list as SAMPLE based? For example, are all audio clips automatically truly sample-based by nature (as opposed to midi clips), and then "converted" to tick-based clips when elastic audio is activated? That is where I am confused. Thanks. |
Hard assets like audio files are sample based. Even when you apply tick based changes the file is still a real sample based file. That is why you have to render things out.
"I did notice that when I enable elastic audio on a track, the clip list changes to indicate tick based...but when a NEW track is recorded (as a tick based track) it still appears in the clip list as sample based."
clip list open, track named "Audio 1" is set to tick based , elastic audio enabled , record armed record , stop : clip list will show 2 clips -> "Audio 1_01.wav/Audio 1_01" , sample based indicator -> "Audio 1_01.wav/Audio 1_01-1" , tick based indicator Seems, recording onto a track with just tick based selected, but not elastic audio enabled, does not show the tick based clip in the clip list. "audio clips are automatically truly sample-based by nature" : nice depiction
sorting clips in clip list | martthie_08 | Pro Tools 10 | 3 | 06-24-2023 12:27 PM |
Spot to Edit Cursor from Clip List ... | ptfigg | macOS | 2 | 03-01-2014 08:53 AM |
How do I select multiple regions in the clip list? | Moviesound | Post - Surround - Video | 5 | 08-25-2012 05:31 AM |
DigiBasePro Import Clip Name List? | Barnaby Bristol | Pro Tools TDM Systems (Mac) | 0 | 11-28-2005 03:18 PM |
