Old 11-07-2003, 06:15 PM
neatguys neatguys is offline
Default shortcuts for half speed +dbl speed recoring
Anybody know if I can even do this?
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Old 11-07-2003, 06:20 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: shortcuts for half speed +dbl speed recoring
half speed record is Ctrl-Shift-spacebar
double speed record - drink 3 cups of coffee and set your tempo to 240
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 11-09-2003, 02:04 PM
lochgarman1798 lochgarman1798 is offline
Double speed? That's easy...just use external sync at 96k, with an outboard A/D converter/clock sync then your song will play at double speed......
I have not tried to record this way butit should work!
JK Cheers
Old 11-09-2003, 02:12 PM
..or use my Header Investigator to adjust the sample rate of the WAV file.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-09-2003, 02:48 PM
Cool thanks everybody!
PT8 half speed playback, what the?! therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-20-2008 03:38 PM
half speed midi? digifriend MIDI 7 10-28-2008 01:22 AM
half speed the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-02-2008 04:27 PM
Can you bounce in Half speed electronicnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-27-2004 08:43 AM
No half-speed playback Sonny Pro Tools TDM Systems (Mac) 0 02-25-2000 11:01 PM
