Old 09-16-2016, 10:56 AM
GS-DK GS-DK is offline
Default Error 6101 - maybe a solution
I have had a huge amount of error 6101 - actually it was almost impossible to work at all - especially with video. I have had remote support from Avid and it seems that we might have "solved" my problem.
After several attempts - downloading PT 12.4, changing playback engine and so on - we unticked the "Minimize Additional I/O Latency" box in the Playback Engine Menu. So far - one days work - I have had NO 6101 errors, so maybe this could be helpfull to other PT users.
Old 09-17-2016, 06:27 AM
digi98 digi98 is offline
Default Re: Error 6101 - maybe a solution
Did you stay with 12.4 or are you on 12.5.2?
Old 09-17-2016, 07:00 AM
I tried both. Now I work in 12.5.2 and so far no problem with 6101 errors.
Old 09-18-2016, 04:56 PM
Creager Creager is offline
This looks like it may very well be the answer we've all been looking for. I just spent the last 2 days doing audio post for a 13 minute video - The SAME video that's been giving me headaches to 2 weeks. It would not play for 3 seconds without a 6101 error. CPU was never taxed for more than 5%.
I've investigated everything. My next step was to swap out the stock Hard Drive in my Mac Book Pro. No other suggestions helped.
Thank you. Thank you. Thank you for this discovery.
The Switch to flip:
Setup
- Playback Engine
-- Host Engine
--- Minimize Additional I/O Latency.
Reboot Computer. (may be unnecessary)
- Start Session
- No issues. NONE.
Pro Tools 12.5.2
Mac Book Pro
OSX 10.11.6
2.8 GHz Intel Core i7
16 GB 1600 MHz DDR3
- Formally trained audio novice.
Pro Tools 2020.10
iMac (21.5-inch, Late 2015)
OSX 10.14.6 (Mojave)
2.8 GHz Intel Core i5
16 GB 1867 MHz DDR3
Digi 003 Rack
Presonus Firestudio
Motu 828mkii
Old 09-18-2016, 05:02 PM
Great to hear. I have had no 6101 errors since I changed this setting. You don't have to reboot it's an instant fix.
Old 09-18-2016, 05:07 PM
"we unticked the "Minimize Additional I/O Latency" box in the Playback Engine Menu."
What interface are you running? This option does not appear on my HD/Native rig
Old 09-18-2016, 05:09 PM
I use UAD Apollo and PT HD. Are you sure you look the right place?
Old 01-30-2019, 02:35 PM
LarsC LarsC is offline
Yep- worked for me to.
Spent many hours in forums. here is the answer. Thanx mate
Old 01-30-2019, 02:38 PM
Now my PT is 2018.12.0 and I still use the solution. Right now in a 2 1/2 hour video session - no trouble at all. I don't dare change the setting:).
Old 01-30-2019, 04:13 PM
The Weed's Avatar
The Weed The Weed is offline
Only available if you first select "Ignore Errors During Playback".
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
AAE-6101 error dipu Pro Tools 11 8 01-06-2021 07:31 AM
Error AAE-6101 ShortwaveP Pro Tools 11 5 04-23-2015 11:50 PM
6101 Error - Potential Solution - Change playback engine to 1 processor Dave Lang macOS 3 11-29-2014 10:52 PM
PT 10.2 6101 error. NEED HELP! Stijn Cole macOS 0 07-01-2012 02:27 AM
-6101 error messages - is there any solution?? I didn't think so. edfreeze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-05-2010 11:23 AM
