Old 08-09-2016, 06:53 PM
[email protected] pqlior@mac.com is offline
Default AAE -20038 when instant Reason9
Hey guys, just installed reason 9 and protools will not launch the plug. keeps giving me AAE -20038. I see that reason gets launched in 'built in' mode and not rewire mode...
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
Old 08-09-2016, 06:55 PM
Default Re: AAE -20038 when instant Reason9
These are my correct version numbers:
Lior
Old 08-11-2016, 09:15 AM
Had to reinstall PT12.5 to fix. It seems that some update for waves killed the rewire plug... Works fine now.
A weird that happened was that after reinstalling PT12.5 it defaulted to aggregate and didn't even have HD native as an option. I had to quit, then launch again while holding N to reselect HD native engine, and then it worked fine...
Lior
Old 08-11-2016, 04:28 PM
I jumped the gun. Next time I restarted the computer- same story.
Protools prompts -20038 and now I have to reinstall.
Please fix!
Lior
Old 08-11-2016, 04:40 PM
Southsidemusic's Avatar
Are you inserting Reason on a AUX track or an Instrument track? Try Instrument track if you have used the AUX track.
Also delete the avid core audio in the HAL folder. That helped others right away.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-12-2016, 10:15 PM
Instrument track. And nothing to do with Hal. Had to reinstall protools and STILL didn't help. Trashing prefs and rebuilding did the trick.
Been consistent for a couple of days now...
Lior
Old 08-15-2016, 05:29 PM
Back on Monday! Still buggy.
Avid? Please help?
Lior
Old 08-15-2016, 06:13 PM
Only after updating to 12.5.2 did it work again. (briefly)
Installed a couple new Waves plugs and now it's not working again.
Oh boy...
Lior
Old 08-15-2016, 06:21 PM
DetroitT's Avatar
DetroitT DetroitT is offline
You ran Reason in standalone 1st?
Quit Reason. Launch Pro Tools only
New blank session
Insert Reason into a STEREO Aux
(Rewire defaults to no-connction)
Choose Mix L Mix R from the rewire plug-in.
Old 08-19-2016, 04:33 PM
That seemed to work... It's still a workaround. If you do it in a different order after startup PT won't load the reason plug and you'll have to restart...
Lior
Reason 8/ PT 12.2/ AAE error -20038 Stig Eliassen Pro Tools 12 10 02-06-2020 06:15 AM
the instant R&B hit formula kiwirock Pro Tools TDM Systems (Mac) 5 01-26-2003 11:34 AM
the instant R&B hit formula kiwirock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-26-2003 07:24 AM
the instant R&B hit formula kiwirock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-25-2003 02:32 PM
instant pull-down? puravidapix Tips & Tricks 4 11-11-2000 09:21 PM
