Old 05-16-2016, 06:37 PM
DementedLegacy DementedLegacy is offline
Default Does this compressor look right?
Hey guys im currently mixing one of my tracks and when i bounce it down and listen to it, it seems like my vocals are pumping. going up and down, i was told this was due to compression. I have a picture here of my settings. Any help would be appreciated!
Plus i only have protools stock plugins. Protools 12.4
Dyn3Compressor/Limiter
Knee: 10 dB
Ratio 4.0:1
Attack: 14.0ms
Release: 25.0
Gain: 2.2 dB
Threshold: -21.4 dB
The input signal is hitting -2 or -3
Old 05-16-2016, 06:55 PM
JuanPC JuanPC is offline
Default Re: Does this compressor look right?
Mixing is an art...
Does my photo sounds ok?
My sculpture?
When you take a photograph and the sun is the strongest, inevitably there will be shadows, depending on the angle of the light, shadows will be stronger or not...
It's the photographer job to know "from experience" how to take the best photograph possible in any light condition.
Almost Everybody knows a decent photograph is even... Not to bright, not too dark.
Compressors are used for many reasons, one is to minimize the difference between the sun & the shadows.
Gates & Downward expanders are used to increase the shadows depth.
Equalizers are light sources, Wide Q is Wash, Narrow Q is Spot light.
But Equalizers also create shadows, like mesh, or light modifiers.
https://en.wikipedia.org/wiki/Nevada_Test_Site#Area_2
--->If you don't like what i wrote:
Click: JuanPC
Click: View Public Profile
Click: User lists^
Click: Add to ignore list.
Solved.
Old 05-16-2016, 07:33 PM
Top Jimmy's Avatar
As a starting point for vocals, try the attack at 35ms, release at 250ms and reduce the ratio to 3:1. Adjust to taste. Don't be afraid of 8-10 dB of compression if necessary. You could also follow this up with a limiter for a more in your face sound. Be creative, try things.
James Cadwallader
Old 05-16-2016, 07:43 PM
cwsand's Avatar
cwsand cwsand is offline
It's not about how it looks, but how it sounds - and that looking at your settings can't really help without hearing it. I realized a few years ago that I'd been using way too much compression on my tracks and have retrained myself to not rely on compression to control my levels, but using some light compression along with other techniques instead. There are always exceptions and every song is different, but this is how I approach mixing these days. It takes practice and time to develop the skills, but don't assume you have to have a lot of compression, or any compression on any given track.
If you're hearing the "pumping" effect, you need to track down what's causing it as it could be the individual vocal track itself, or compression on a submix aux channel, processing on the whole mix, or a combination of all of those. You could start with muting all but the vocal track and adjust the compressor to where you like the sound, then start unmuting other tracks one by one to try to find out what's causing the problem. Or you could mute all the compressors in the mix and unmute them one by one to see what effect they have on the whole mix. It should be fairly simple to identify which plugins are causing the problem and adjust them to resolve it, but then the mix may need further adjusting with the altered levels.
Hope that helps!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-16-2016, 07:55 PM
TrentWilliams TrentWilliams is offline
Pull your attack back, and release forward.
That'll stop the pumping.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 05-16-2016, 08:36 PM
sw rec sw rec is offline
-21 threshold???? Try -4 or so.
Old 05-16-2016, 08:38 PM
So slower attack and faster release?
Old 05-16-2016, 08:39 PM
YYR123's Avatar
YYR123 YYR123 is offline
Well he doesn't tell us what his RMS levels are....so maybe it's recorded at a low level???
Daniel
Old 05-16-2016, 08:40 PM
YYR123's Avatar
No opposite
Fast attack and slow release
Daniel
Old 05-16-2016, 09:08 PM
A fast attack will pull the volume down faster (obviously), a slower release will make the drop in volume longer which will cause a pumping effect.
Especially if it's transient material you're working with.
Slower attack and faster release will give you more transparent compression.
Fast attack will soften the transient material, I don't often use it this way as you will lose a lot of texture.
But that's just my opinion.
My go to compressor is the Softube Tube-Tech CL-1B. I dial the attack around 2:00, and release around 10:00 usually to start off with. Then i'll bring down the threshold until i'm getting a desired compression level.
That's for a general bus compression, or subtle transparent compression.
If I need something a little more aggressive, i'll dial the attack forward until i'm hitting the compressor just after any transient material. This means I still retain texture and minimise pumping, then bring the release back to taste or the speed of the transient attack so the compressor is releasing just before the next compression point.
Master Fader Limiter/Compressor SSL Compressor mesa3077boogie Pro Tools 9 8 07-11-2011 08:15 PM
URS Console Strip Pro compressor/URS individual compressor Anibal Pro Tools TDM Systems (Mac) 4 08-15-2007 12:44 PM
McDSP Compressor Bank or Farichild Compressor joji Pro Tools TDM Systems (Mac) 7 10-31-2005 09:20 PM
Broadband compressor after multi-band compressor? phanatik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-20-2005 09:02 AM
Does the WAVES R. Compressor have factory presets like the DigiRack Compressor? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-23-2002 07:51 PM
