Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 11-14-2015, 03:39 PM
LoZion's Avatar
LoZion LoZion is offline
Default 2nd ilok
Quick question, I still use v10 on a os10.8 setup and am eligible to a free upgrade to v12. I have a spare ilok hanging around so can I dl v12 on the 2nd ilok and try it with osx El capitan on another Mac or do I have to surrender the 10/11 bundle first? Txs.
"The secret in life is to have no fear"
Fela Anikulapo Kuti
Old 11-14-2015, 04:19 PM
nigelpry's Avatar
nigelpry nigelpry is offline
Default Re: 2nd ilok
When you upgrade, you surrender your existing 10/11 bundle and receive a 10/11/12 bundle.
You can't split the bundle so you can only run Pro Tools on one computer at a time, but you can keep PT10 installed on your older computer if you want, and install PT12 on the other Mac with ElCapitan. Just move the iLok between computers dpending on which ine you want to use at a point in time.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 11-14-2015, 04:35 PM
LoZion's Avatar
So in essence Avid considers the 12 upgrade as the same license even though they are different engines.. Bummer for convenience's sake.. Txs.
Fela Anikulapo Kuti
Old 11-14-2015, 05:57 PM
LoZion's Avatar
Anyone else has a different experience to report?
Fela Anikulapo Kuti
Old 11-14-2015, 06:01 PM
Southsidemusic's Avatar
You already have the answer from Nigel!
You can't split a ilok license asset from the ilok so you can install PT on 100000 computers but you can only use one at a time with the ilok the license lives on.
You get 10/11/12 when upgrading and you can have PT10 and PT11 or 12 co-installed on the same partition as long as the OSX version support it.
So .. Thats about it really.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-14-2015, 07:00 PM
LoZion's Avatar
Ok so 12 and 10 can coexist? Good I thought that only worked with 10/11. Cheers,
Fela Anikulapo Kuti
Old 11-14-2015, 07:10 PM
jeffro's Avatar
jeffro jeffro is offline
Yes, on OS X 10.8.5. See http://avid.force.com/pkb/articles/d...12-3-Downloads for co-install info.
• linkedin •
Old 11-15-2015, 01:59 AM
nigelpry's Avatar
Only a 'bummer' really if you had hoped to run Pro Tools on both computers simultaneously, or if you had hoped to sell off the PT10 license after upgradng.
And that's the point .... you currently have a license that allows you to run PT on one computer at a time, and after upgrading it, you still have a license that does the same, but allows you to choose to run any of three versions (10/11/12) instead of two versions (10/11).
If you want to run it on two computers at the same time, buy a second license, or subscribe (rent a license). You can stop/start subscriptions a month at a time if you only need a second computer simultaneously occasionally. Bear in mind that the subscription license will be PT12 only.
Old 11-15-2015, 07:24 AM
The Weed's Avatar
The Weed The Weed is offline
Or buy a second iLok for the second computer and move your license between the iLoks using the iLok License Manager.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-15-2015, 10:57 AM
roberts roberts is offline
Absolutely you can run it simultaneously on 2 machines - but you have buy 2 licenses!
FS: Pro tools HD9 transferable to Ilok account €250 (paypal and ilok fees included) Mikek33 Buy & Sell 1 12-02-2014 04:39 AM
ilok issues - ProTools 9 crossgrade LE (Please install the iLok Client Software) pauledwards Windows 3 09-10-2013 04:02 PM
Plugin auth weirdness - guest iLok prevents internal iLok? Scott Helmke VENUE Live Sound Systems 3 09-07-2011 07:06 AM
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-07-2009 03:51 AM
Transfer iLok auth. from old iLok to new 003 factory iLok? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2007 07:05 PM
