Old 11-26-2012, 01:44 PM
viaspiaggia viaspiaggia is offline
Default SPEED not rendering correctly
Forgive me if there is somewhere better to post, but I couldn't find any sound toys forums so thought I'd ask here.
I just got the SPEED plugin and am trying to use it to do a classic slow-down-pitch-and-speed effect, like just grabbing the varispeed knob and rolling it down.
It previews great but the result from AudioSuite only gives me a fraction of what should be the resulting file. Changing the various processing methods (individual files vs continuous, etc) gives varying results but it's never what I heard in the preview. usually the new file length is correct, but there's only audio for the first half of the time (or less).
Any thoughts?
PT10.2.0, Mac 10.6.7, MacPro 1,1
Mac mini 2018 i7
ProTools Ultimate Native
Focusrite Scarlett 18i20
Atmos 7.1.2
hugmonstersound.com / unheardof.world
Old 11-27-2012, 05:28 AM
Postman Postman is offline
Default Re: SPEED not rendering correctly
SPEED got a little buggy with PT10. There is similar problem when using it with the time expand trimmer tool. The resulting file is the right length but the audio inside is usually wrong. I don't think the bug has been fixed yet but SoundToys knows about it.
I still use Speed regularly but only with the knobs or graphic interface, and always get the results I expect. Are you saying you set the knobs, preview, render...and get bad results? Do you have a handle length set in PT preferences? I usually keep handle length set to zero, maybe that is part of the problem?
Old 11-27-2012, 06:46 AM
Using graph mode, and yes I set it, preview, sounds great, render, and the audio is goofed up (file length appears right as you say).
Not sure what my handle pref is set for - I believe it defaults to 2 seconds, and I also tried whole file, but may not have tried zero handles - I'll give that a shot later.
Thanks.
Mac mini 2018 i7
Atmos 7.1.2
Old 11-27-2012, 11:59 AM
brilliant, ramping the handle down to zero makes it work - thanks Postman, not sure how I missed that when troubleshooting.
Mac mini 2018 i7
Atmos 7.1.2
Old 11-27-2012, 07:46 PM
At least you have a workaround. It's too bad. Speed is such a great tool! I hope they fix it.
Old 11-27-2012, 09:05 PM
capt kirk capt kirk is offline
said it before and i'll say it again, the intellects at AMS NEVE need to package thier reel rock record varispeed code into a PT plug....works so fast and hifi..
www.kfaudio.ca
HTML code is On
Rendering with X-Form How? Numi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2008 08:20 PM
Film Speed/Video Speed Workflow Confusion! subwoof Post - Surround - Video 13 08-23-2008 09:03 PM
Playback at double speed / higher speed in LE? Chris Nelson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-26-2008 09:28 AM
Mp3 rendering in 6.4 Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-14-2007 10:18 AM
shortcuts for half speed +dbl speed recoring neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-09-2003 02:48 PM
