Bus Menu A, Bus Menu B etc
this is driving me crazy.. new feature in PT9 - when I´m importing stuff from other sessions I´m getting Bus Menu B (sends) instead of adding them to all my other busses
at the moment I have to go to my PT8 LE to open the session there and then go back to PT9 to get one bus menu but maybe there is another workauround to only have one bus menu?? thx for help |
Re: Bus Menu A, Bus Menu B etc
THis happens if you have two buses with the same name such as bus 1-2 and Bus 1-2 Just delete one (the one you are not using), or if it is the one you want to delete, just change that bus on your Input Outputs. Suddenly, one Bus menu. I would prefer being warned at the time, but this is part of the complication of dealing with multiple namings which can easily happen.
Not sure if this is what you are talking about, but you are aware that you can Import/Export I/O settings including buss's.
In PT Setup>I/O>Import-Export settings
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
I leave this unchecked as I do not usually want to import stuff for mixing. Logically it should not bring names and such with it, but it does. It's a drag really. Easy enough to fix, but why needlessly spend time on it?
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
hey guys
thx for your help - I´ll check that |
not in LE.. I guess - at least cant find it
Alt-menu keyboard shortcuts - Alt+F for file menu, etc. | scullionj | Windows | 7 | 11-22-2015 08:59 AM |
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! | a2zproductions | Pro Tools TDM Systems (Mac) | 16 | 05-08-2008 08:30 AM |
Help menu? | davyped | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-16-2007 08:39 AM |
help menu | josh002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-06-2004 06:13 AM |
Help Menu | jiagap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-22-2001 05:33 AM |
