Old 03-13-2011, 08:12 PM
lexaudio lexaudio is offline
Default Why is copy plugin automation greyed out?
8.04cs2 HD6, 10.5.8
Old 03-14-2011, 07:21 AM
suicune suicune is offline
Default Re: Why is copy plugin automation greyed out?
Erm - because you don't have any plugin automation data selected?
If it's not that then perhaps you should provide some more information to get some help:
http://duc.avid.com/showthread.php?t=193636
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 03-14-2011, 09:29 AM
ERRR, LEt me be a little more clear,.
If I select an Aux, it is there.
If I select a region, I can copy all automation.
If I select a region, I cannot copy plugin automation, but can copy all automation, which makes ZERO sense.
Does the only way it work is by opening every automation parm and copying them one by one?
Old 03-15-2011, 01:13 AM
PierrevC PierrevC is offline
If I'm not mistaken you have to put your automation lane on one of the plugin automation to let protools know from which plugin you want to copy your automation...
I use option-shift capture to capture all plugin automation on the selected tracks at the current cursor position...
it works much better in my post workflow. Nice feature is that you can sum up the automation from different tracks and if you option-shift punch the captured automation only drop the automation on the selected tracks
cmd-capture clears the "capture memory"
Copy/Paste plugin automation Rune Thuelund Post - Surround - Video 18 03-28-2012 01:35 PM
Copy/Paste Special Plugin Autom: greyed out? SD2 macOS 2 10-19-2011 01:34 PM
Copy Plugin automation impossible HiLoc Tips & Tricks 3 02-19-2011 02:17 PM
Copy plugin automation only Studio Studio Pro Tools TDM Systems (Mac) 6 11-19-2010 09:58 AM
Copy special>plug-in automation is greyed out Studio Studio Pro Tools TDM Systems (Mac) 6 05-12-2010 01:36 PM
