Old 06-04-2010, 08:47 AM
barry1 barry1 is offline
Default giga files
do any pt 8 instrumtnets support giga file?
Old 06-06-2010, 01:37 AM
Default Re: giga files
Structure 1.1.0 supports Giga.
Aaron Mulqueen - 001 HD Native
Old 06-27-2010, 03:29 PM
Mark Wheaton Mark Wheaton is offline
Is there any specific info posted that explains step by step the best way to import Giga libraries?
When I open a Giga Library, all the patches load together in Structure, you must then Save As each patch to be able to access each individual patch. Also, some of the features such as Mod wheel filtering etc seem to be absent.
Any detailed info would be appreciated
I have Structure 1.1
Old 06-27-2010, 09:38 PM
lkingston lkingston is offline
I have had terrible luck trying to open giga files directly in Structure. On the other hand Chicken Systems Translator converts giga to Structure quite well.
laurencekingston.bandcamp.com
Old 06-27-2010, 11:13 PM
GeneOuse GeneOuse is offline
This plugin is THE thing for GIGA files. Structure is terrible with GIGs.
Old 07-02-2010, 08:13 AM
Do you have first-hand experience with this giga-player? I have a bunch of Gigasampler files (including the Miroslav orchestral library), some of which I've converted to Structure or Kontakt using Chicken Systems translator, but the conversions are never perfect and it is time consuming to go through this process. Also, I've had issues with Gigasampler sounds that use data compression. The conversion sometimes doesn't work and when it does, the converted files are much bigger. Does this player play back these files perfectly? I may need to get it.
Old 07-02-2010, 04:45 PM
The various samples that I have it plays without issues. Try out the demo and see if it'll do the same for you.
Old 07-02-2010, 07:48 PM
I just installed the demo. It installed a VST version but no RTAS version. I see in their web site that it is supposed to work with Pro Tools and RTAS. Is there something extra you need to do?
does pt support giga files barry1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-04-2010 08:46 AM
Giga/.EXE files? logandrum Virtual Instruments 0 02-28-2008 08:06 PM
USING GIGA FIlES WITH KONTAKT??? Johnny916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-09-2004 01:52 PM
Tascam Giga Studio Giga Sampler Help discodan Pro Tools TDM Systems (Mac) 2 05-13-2004 01:23 PM
