Old 05-17-2010, 12:13 PM
buckaroo buckaroo is offline
Default Audio editor for PT?
I know this may seem a stupid question, but is there a way to double click a region and select an 'audio editor' for PT?
I use Soundforge for some things as a dedicated 2 track editor, and doing some fx and editing which i can't do in PT
Is there a setting to set an ext editor in PT8?
Old 05-17-2010, 12:24 PM
DrFord's Avatar
DrFord DrFord is offline
Default Re: Audio editor for PT?
No.
Pro Tools is the audio editor.
You can however right click the region in question and then "Export Region As..." and export it to your desktop, then edit it with Soundforge, then bring it back into the pro tools time line. If done correctly, you could use the spot function and it will put it back on its original starting point.
But no, Pro Tools will not let you pop open a separate editor inside the edit window a la Cubase or Logic.
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 05-17-2010, 12:33 PM
Dizzi45Z Dizzi45Z is offline
If you don't mind me asking, what kind of audio editing are you missing in Pro Tools?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 05-17-2010, 01:10 PM
i think that I am used to SF more than PT, and would love to use both together as a best of both worlds..
In SF, I can do the pitch bending with the graphic interface, that you can't seem to do as easy on PT with vari-fi
Also the way that you can 'flatten' a file and overwrite as a sample in SF, but with PT you have to export etc, there doesnt seem to be a quick way to save part or whole of a region as a new sample?
Old 05-17-2010, 02:40 PM
Mark Wheaton Mark Wheaton is offline
NOt sure about the Pitch editor, although Melodyne works well for this, however your other needs are addressed in the Edit Window with the edit tools combined perhaps with some audio suite stuff. Overwriting a sample with a new selection if I am reading you right is done either as an Export Region as file under the Region list, or a Consolidate command. Read the Manual.
Old 05-17-2010, 04:40 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Bring Back Sound Designer!!!
Sometimes it would be nice to have a destructive editor available in Tools.
(They could put a Kick A*se batch convertor in there too)
Old 05-17-2010, 10:47 PM
Sean Russell Sean Russell is offline
Try the elastic audio vari-speed.
Between AudioSuite, the SmartTool and Elastic Audio, editing is *definitely* in PT for me.
And if you consolidate or use AudioSuite plugs / fx, you can open the project browser, arrange by modified, and your newly effected file is at the top. (works with Finder, too).
So I'm not sure if I understand that it doesn't do what you want, just that you're not used to looking for the file where it is after processing, maybe?
... but does it help the chorus?
Old 05-17-2010, 11:17 PM
Imagine you're using a sfx clip about 600 times at various points, on various tracks in a session and you want to change it to another sound. Grab a destructive editor and copy and paste new audio directly into the source wav file and you've saved yourself a lot of stuffing around. I don't know if this is what Buckaroo is getting at, but it certainly can't be done with an audio suite plug.
(There may be a replace region function that I don't know of, but sometimes a simple wave editor can be very handy)
Old 05-18-2010, 12:14 AM
Rammelt Rammelt is offline
You can Replace Regions, yes, and switch the audio file for those 600 spots in 2 clicks
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Old 05-18-2010, 12:27 AM
No - but if you're using Sound Forge then you must be running Windows... so this may be useful: http://www.railjonrogut.com/Region%20Synch.htm
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Standalone Audio Editor manilarice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-28-2010 02:55 PM
Best free audio editor? YoRugMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-22-2010 03:20 AM
Simple MP3 Audio Editor ProductionEngelads 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-27-2002 07:12 AM
what audio editor for mac? polnetwork.com Pro Tools TDM Systems (Mac) 3 10-21-2002 08:43 AM
Cubase as midi editor and PT LE as audio CFS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-01-2001 12:33 AM
