Old 03-23-2010, 03:26 PM
Mark Wheaton Mark Wheaton is offline
Default Standalone Play setup
I have Play and I am trying to get it to work as a standalone player on the same machine as my Pro Tools HD. I got the IAC bus working, but I can't seem to get the routing right for Optical output.
I have a lightpipe cable coming out of my MacPro (digital Output-Optical). I set Built In Digital Output in Audio/MIDI Setup. I connect this to my 192 I/O Input. The input I picked is the Optical Input next to the SPIDIF and Sync Connectors. This is on the right side looking from the back. I also tried the ADAT Input in the middle of the back of the 192. I select the input that shows up in I/O setup and create an input path. I use that input as the input on a Aux or Instrument input.
When I play notes I can see Play responding, but I do not hear output. Any suggestions as to how to get this to work?
Old 03-23-2010, 03:59 PM
Lizardpoint Lizardpoint is offline
Default Re: Standalone Play setup
Is there a reason you can't use it as an RTAS plugin ?
Lizardpoint
Old 03-23-2010, 06:47 PM
lincol1 lincol1 is offline
I'm just a mere hobo, but if you haven't already make sure your optical input is set to SPDIF not ADAT.
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 03-24-2010, 11:13 AM
Thanks Lincoln, that worked. But, it means (I Think) that you have only one stereo output from the Standalone back into your interface.
Is it possible to make the ADAT Optical input work coming from the Optical out of the MacPro so you get multichannel audio out of the standalone?
As to why I am doing this instead of RTAS, I am not. I just want to see how to make it work, and to see if it makes a difference in performance.
Old 03-27-2010, 06:20 AM
Glad you had some success w/ that.
Yup - The optical out of the Mac Pro is stereo so you will not be able to do multi channel out with that set up.
You'd need another interface (1 for PLAY 1 for PT)
These are the kind of limits that have made PT almost obsolete for me.
(lizard) I used to use play standalone alot with PT not because it didn't work as an RTAS plug in but because after 10+ instances it would cripple PT.
With multiple standalones I was able to get better results.
Then after switching to logic, which took a while to get comfortable with, I was able to use my 003r as the audio out in PLAY - and the interface in Logic making it possible for multiple outs with the standalone version.
I could physically route the outs to ins on the interface and it worked great.
Then Logic 9.1.1 came out in 64 bit and I have tossed VE ensemble pro and all standalones and run everything native.
It's ridiculous. Hundreds of VI's - it's pretty sweet.
Now remember I'm just a mere hobo - And I'm only speaking for my needs, workflow - Pro Tools is still amazing etc etc...
Good luck.
Lincoln Mitchell
www.studiofifty.net
Notation view edit while in play cause play to stop working. soybalm Pro Tools 10 1 04-18-2013 11:11 AM
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
play flashes then stops. session wont play. hellbert Windows 21 03-31-2011 10:49 PM
When press play the stop key lite and play key blinking Sam Yin Tips & Tricks 6 12-05-2009 08:26 PM
Setup help needed re: midi and ASIO in standalone. ecalcagnino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-30-2004 12:24 PM
