Old 11-28-2009, 01:09 AM
MrBibidy MrBibidy is offline
Default Other time signatures with Boom other than 4/4
Anyone know how to get Boom to follow other time signatures?? Like 5/4
James Hurley,
Int'l Freelance Producer & Mix Engineer
http://www.Abravemix.com
Old 11-29-2009, 04:31 PM
Default Re: Other time signatures with Boom other than 4/4
Ok so I got 5/4 to work, seems Boom doesn't follow meter changes on a timeline. If I start a session with x/x meter it will stick with that meter even if I insert a meter change on the tempo map.
DigiTech maybe have a look at this and see if its still an issue in the 8.03pr I still havent updated cause I aint gonna fix whats not broke until there is a serious release.
James Hurley,
Old 11-29-2009, 06:04 PM
Correction, it will follow meter changes only if the region containing the notes is created once the meter is set. If you make a region with notes on say a 4/4 measure and then change the measure to 5/4 it will play 4/4 no matter what. At least thats in the one session I tested. Sorry DigiTech, would you like me to test it further? Or does it not matter due to the version I am running (8.0cs3)?
James Hurley,
Old 11-29-2009, 07:03 PM
Boom does follow the session meter as long as the beats in the metric cycle tell it so but like Strike anything more than simple time signatures sound less convincing. The obvious workaround is to sequence on the timeline where compound and asymmetric meters can truly shine.
filosofem
Old 05-21-2010, 12:53 AM
henrikas henrikas is offline
Hi James,
I´m trying to get Boom to work in my 5/4 session. Could you please explain how you made this work?
- my session starts with 5/4 meter, but Boom keeps its 4/4 no matter what..
Cheers,
Henrik Skram
composer
Oslo, Norway
www.horbart.no
OS Ventura 13.5.2 - Mac Studio
Protools Ultimate 2023.9
RME Fireface UFX
Henrik Skram
filmcomposer - OSLO
Using BOOM with Odd Time Signatures (3/4....6/8) NYKeys Virtual Instruments 9 07-25-2023 02:00 PM
Set up PT for 3/4 5/4 6/8 ... time signatures KGB2011 Pro Tools M-Powered (Win) 4 10-11-2010 07:38 PM
Crazy time signatures... SFR General Discussion 1 01-25-2010 01:24 PM
Using different time signatures within the same song David Penick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2009 06:43 PM
two different time signatures in one session? elv1s1sal1ve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2006 07:36 PM
