#41
Re: just updated to vista, now pro tools does not work
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#42
i could try to install pt8 again i guess, it couldnt hurt, worse thats going to happen is, it wont work, and im gunna have to dualboot or emulate anyways lol
#43
if you decide to multi-boot, think about carvin' out your partitions while booted from your current Vista OS. then when you throw in your XP install disc, make sure when your choose your language that you look for the 'advanced' menu (or whatever they call it) to let you select the partition you want XP installed on. my 2cents anyway. don't forget about doin' backups/images along the way...makes recovery less painful
#44
#45
#46
no go. tried compatibility mode and deleteing folders, even updatd pace drivers too. im gunna uninstall, maybe vista installed the digi 002 drivers when i installed the os, and they were less up to date than the ones with the pt disc, so its having issues.
#47
that fixed the hardware is not on error. pro tools opened up, i made a quick session, set up a track an hit record, get buffer errors now. my processor and ram didnt change, so iuno why thats happening now
#48
When launching Pro Tools in Vista Right Click the Pro Tools icon and choose Run As Administrater. This is how the guys at Digi ALWAYS run PT, which may explain why they have a hard time figuring out why end users are having so many problems. Since I started launching this way EVERYTIME all errors have disappeared. Im rock solid, i even have IE8 installed, i had IE8 open and PT open at the same time today and everything runs great.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
#49
??? Pro Tools works on Windows?
/s |
#50
its some kind of latency issue now. becuz it opens fine now, it just wont play for more than a second or two no matter wat i set the buffer to. its not the hdd either, cuz now its 7200 rpm 32mb cache |
M-Audio C600 Updated Drivers - Don't Work. | thisbridgehascables | FireWire & USB Audio Interfaces (Mac) | 6 | 04-23-2014 06:30 AM |
Will LE 6.9.2 work under updated Mac OS? | Edo Peters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-24-2008 04:04 PM |
Need a driver for the mbox to work 7.4 LE pro tools on vista | masta1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-18-2008 02:20 AM |
Updated to Intel/updated plugins don't work | Mixtrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-09-2007 07:59 AM |
SSD..updated firmware, now light just flash, doesn't work!! HELP!! | maxtraxstu | Pro Tools TDM Systems (Mac) | 6 | 01-18-2000 03:52 PM |
