just updated to vista, now pro tools does not work
ive literally spent an entire day installing and uninstalling pro tools, being stuck on a 32 bit operating system is already annoying me, i'm pretty much about to sell my 002r and buy a motu + cubase or somthing else that is actually reliable.
here's a list of the methods ive tried and the results: -install pt8 on a freshly installed vista: pt installs, on first open, gets stuck on either dae or preferences, dont remember. tried running in compatibility mode, normal, user account control is turned off, same issue. -complete uninstall, removall of folders, etc, then install of pt 7.4: "pro tools has stopped working" error after install and first run. compatibility mode has no effect, user account control is off. here's probly the most interesting part of them all. i remember reading people getting 64bit vista working by installing and uninstalling 7.4, but keeping folders and preferences, then installing 8, so i tried that. -uninstall of 7.4, keep folders/preferences/drivers, and install pt8: works...sort of. the program acts like i have no ram and the processor from the stone age. with buffer times increased or using settings that previously worked in xp, the most i could get, was sound playing for a second maybe two, then it cuts off with a buffer overrun error. -uninstalled 8, reinstalled 7.4, uninstalled and left folders/preferences/etc like the time before it: works again, less of a buffer isssue this time, but a loud whining noise plays constantly on all tracks..and even shows visually on the volume faders.. wierdiest thing ive ever seen. tried opening different sessions, compatibility mode, turning on and off different hardware. same thing -complete uninstall again. re-download of pt 8 (get the same files, so that was a waste), reinstall of pt 8, update pace drivers again just to be safe, uninstall internet explorer 8, delete preferences folders, etc: pro tools installs and loads and hangs at "reading preferences" -uninstall and reinstall exactly as above: pro tools installs and first launch yeilds "pro tools has stopped working" i'm completely baffled how a system that one day ago functioned perfectly fine with pro tools since 6.4 to pt8, now can't run any of them, and gives a different result at every install. |
Re: just updated to vista, now pro tools does not work
Which version of Vista? If it's 64-bit, it's not compatible. There are dozens of threads on this already.
Post a Sandra Report (located in the "Help Us Help You" thread) and so w can get a better idea of your specs.
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
^^32 bit ultimate...i know i didnt state that, but i wouldnt try to install it on something that downright wasnt compatible, and i did make references to being stuck on 32 bit and such. forgive me for leaving the sandra print out, like i said, this is a fresh install, i was literally downloading sandra right now to edit my post, i didnt think anyone would reply so quick. heres the print out:
SiSoftware Sandra System Model : ASUSTEK COMPUTER INC P5W DH Deluxe Workgroup : WORKGROUP Host Name : Studio User : War Machine Processor Model : Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing System Mainboard : ASUSTeK Computer INC. P5W DH Deluxe BIOS : American Megatrends Inc. 2801 (07/10/2008) Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS 82975X Memory Controller Hub Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 8GB DIMM DDR2 Memory Module(s) Memory Module : Kingston 2G-UDIMM 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : Kingston 2G-UDIMM 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Video System Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.7GHz, 512MB DDR3 2x1.12GHz, PCIe 1.00 x16) Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.7GHz, 512MB DDR3 2x1.12GHz, PCIe 1.00 x16) Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.7GHz, 512MB DDR3 2x1.12GHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 9800 GTX+ (128SP 1.84GHz, 512MB 2x1.12GHz) Adapter : NVIDIA GeForce 9800 GTX+ (128SP 1.84GHz, 512MB 2x1.12GHz) Storage Devices WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) : 932GB (C:) (D:) (E:) (F:) (G:) (H:) (I:) (J:) SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (O:) (P:) (Q:) (R:) (S:) IOMEGA ZIP 250 (ATA) : N/A (B:) WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (K:) (L:) (M:) (N:) Sony USB HS-CF Card (USB) : N/A (W:) Sony USB HS-xD/SM (USB) : N/A (X:) Sony USB HS-MS Card (USB) : N/A (Y:) Sony USB HS-SD Card (USB) : N/A (Z:) SATA HL-DT-STBD-RE G (RAID, BD-RE, DVD+-RW, CD-RW) : N/A (T:) HP DVD Writer 840b (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (U:) Logical Storage Devices Removable Drive (B:) : N/A @ IOMEGA ZIP 250 (ATA) Main OS (C:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Hard Disk (D:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Hard Disk (E:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Hard Disk (F:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Videos 2 (G:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Hard Disk (H:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Hard Disk (I:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Music (J:) : 116GB (NTFS) @ WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Hard Disk (O:) : 10GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Production (P:) : 110GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Sessions 1 (Q:) : 112GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Sessions 2 (R:) : 112GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Sessions 3 (S:) : 121GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) backup prog (K:) : 116GB (NTFS) @ WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) backup misc (L:) : 117GB (NTFS) @ WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) games (M:) : 117GB (NTFS) @ WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) videos (N:) : 116GB (NTFS) @ WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Optical Drive (T:) : N/A @ SATA HL-DT-STBD-RE G (RAID, BD-RE, DVD+-RW, CD-RW) Optical Drive (U:) : N/A @ HP DVD Writer 840b (ATA33, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Removable Drive (W:) : N/A @ Sony USB HS-CF Card (USB) Removable Drive (X:) : N/A @ Sony USB HS-xD/SM (USB) Removable Drive (Y:) : N/A @ Sony USB HS-MS Card (USB) Removable Drive (Z:) : N/A @ Sony USB HS-SD Card (USB) Peripherals LPC Hub Controller 1 : ASUS 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627DHG Audio Device : ASUS 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semiconductor 0882h Serial Port(s) : 1 Disk Controller : ASUS 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : ASUS 82801GB/GR/GH (ICH7) Serial ATA Storage Controller Disk Controller : ASUS P5B [JMB363] USB Controller 1 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 2 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 3 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 4 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 5 : ASUS 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Scanners and Cameras Digital Camera : IOMEGA ZIP 250 (USB) Digital Camera : USB HS-CF Card (USB) Digital Camera : USB HS-MS Card (USB) Digital Camera : USB HS-SD Card (USB) Digital Camera : USB HS-xD/SM (USB) Network Services Network Adapter : Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller Network Adapter : Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller #2 (Ethernet, 100Mbps) Wireless Adapter 1 : Realtek RTL8187 Wireless 802.11b/g 54Mbps USB 2.0 Network Adapter (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Ultimate 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 5.3 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
I'm sorry, you probably mentioned this also but the thread is a bit long and I guess I have A.D.D. But did you say PT worked on this same puter with XP and 7.4? Do other PCU hogs run on the new setup? (like a video editing program?) This sounds like a problem I had while doing some upgrading I had to swap out a perfectly good ATI video card because it didn't play nice with Vista 32. When I posted about it a lot of people replyed that they switched from the NVIDIA GeForce 9800 GTX to an ATI. (exactly the opposit of what I had to do) It may be worth a try?
Is there any chance you have installed I.E.8?
It may be worth a try to go back to SP1.
Even though most have had little or no issue with SP2, Digi says the following:
what OS did you use prior to your latest install?? XP?
WDC WD10EACS-00D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) : 932GB (C:) (D:) (E:) (F:) (G:) (H:) (I:) (J:) <=== this would be of concern to me. Vista brings a lotta bloat that XP didn't have. and this slow spinnin' drive 'could' be part of your problem.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
...And all of the partitions on the system drive cause me to ask, where is PT installed?
I was wondering the same thing.
Benoni, it amazes me how you seem to get different results on computer issues here than nearly everyone else.
In the past month alone I have reverted two clients systems back from Vista ultimate to XP Pro . The performance difference with XP installed is stark. You live a charmed life. :) |
M-Audio C600 Updated Drivers - Don't Work. | thisbridgehascables | FireWire & USB Audio Interfaces (Mac) | 6 | 04-23-2014 06:30 AM |
Will LE 6.9.2 work under updated Mac OS? | Edo Peters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-24-2008 04:04 PM |
Need a driver for the mbox to work 7.4 LE pro tools on vista | masta1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-18-2008 02:20 AM |
Updated to Intel/updated plugins don't work | Mixtrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-09-2007 07:59 AM |
SSD..updated firmware, now light just flash, doesn't work!! HELP!! | maxtraxstu | Pro Tools TDM Systems (Mac) | 6 | 01-18-2000 03:52 PM |
