Old 03-18-2009, 05:49 AM
sammyfarr sammyfarr is offline
Default PT8 Revibe Freakout
Im having problems with the latest version of Revibe on PT8cs2 HD6, Osx10.5.5, G5 dual 2ghz, 4 gig of ram, expansion HD. Occasionally Revibe makes a noise like it's feeding back, overloading the channel output even though all routing is fine. Other times the reverbs are distorted. Removing the plugin then reinstantiating it does not fix it. Re-booting tools does.
This is one of many problems im having since moving to pt8/leopard on this rig. losing communication with the expansion chassis is the most common problem. it gives me dae errors 9161 and 7401 before crashing but ill wait till ive done a bit more troubleshooting before posting details about that.
Its also worth pointing out that we have an almost identical rig that seems to be running fine.
Anyone else having troubles with Revibe?
Cheers
Sam
Old 03-18-2009, 06:43 AM
Peter Duemmler Peter Duemmler is offline
Default Re: PT8 Revibe Freakout
Same thing with Revibe here (without Expansion Chassis).
Support should already have that on their screen...
Peter
http://www.merlinsound.de
Old 05-16-2009, 02:09 PM
vadimlisa vadimlisa is offline
Hello! I Have the same problem.
You can try to resolve with this:
1. H/W buffer size must be 1024 or better
2. Use the ProTools Pref and Database Helper to delete all pref's
3. Clean all cashes with Leopard cash cleaner.
4. Reboot MAC.
But i know - after 2- 3 days - errors will return.
DIGI PLEASE HELP!!!!!!!
PT HD8; Expansion chassis with HD4; Mac PRO 8-core 2,8G; 6 Gb RAM; 192; Neve 8816.
Old 05-16-2009, 06:21 PM
IO Composer IO Composer is offline
+1
Same issue here. Not a big deal to reboot PT, but still...
Jamey Scott
Dramatic Audio Post, Inc.
Burbank, CA
IMDB
Old 05-16-2009, 08:10 PM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
+1
Old 05-17-2009, 05:41 AM
Tobias Eichelberg Tobias Eichelberg is offline
Oops. Doesn't sound too good.
On my MacPro, the user interface acts very sluggishly since i upgraded to 8.0cs2. I re-installed ReVibe with the latest installer, but the strangeness remains. Though i don't get the feedback mumbo-jumbo...
Toby
Old 05-17-2009, 06:50 AM
colinweeks colinweeks is offline
i've had the feedback issue as well and i *think* it only happens when DSP cache is turned on... has anyone had the feedback issue with it turned off?
Old 05-17-2009, 08:42 AM
crizdee's Avatar
crizdee crizdee is offline
I always have the cache off and i've never encountered this problem!
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-18-2009, 12:08 PM
DigiTechSupt's Avatar
I'm curious if turning off DSP caching 'fixes' the problem for others as well.
The reason being - we're looking into issues with 3rd party plug-ins and DSP cache.
Are all your plug-ins up to date? Have you verified them against the Pro Tools Plug-in Compatibility Grid?
Avid Audio Tech Support
Support FAQ
Old 05-18-2009, 12:19 PM
johnnyv johnnyv is offline
I haven't experienced this problem, FWIW. Does it happen reliably or is it a random occurence?
Structure LE Freakout and crazy colours! engininja Pro Tools 9 3 12-18-2010 01:37 PM
no fw400 freakout? therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-05-2009 08:19 AM
Drive Freakout and Static Ggolden 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-22-2005 08:31 PM
Digi001 freakout 001fran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-03-2002 11:20 PM
please help: samplecell plus and magma 13 freakout harry maxon Pro Tools TDM Systems (Mac) 1 08-22-2001 06:35 AM
