Re: How To Set Up Strike With V-Drums
I recommend finding a kit that you like in Strike(Or building it from scratch), and then play a few patterns to see if it has the sound you are after. You could then do it one of two ways:
1) Create new midi channels for each input, and assign the midi inputs to your individual drum triggers and the midi outputs to the corresponding midi channels in Strike. 2) The shortcut: Play a pattern or 2. Export it to midi, which creates all the channels used in that kit. The best part is, the Strike channels(midi outputs) are already assigned and labeled(Saving you a bunch of work!), so just assign the midi inputs to your corresponding drum triggers. Wipe out the midi data that was placed in those tracks by Strike to start with a clean slate, and away you go!! That being said, if you want to use Strike as a sound module only, you might be better off with something like Battery 3, which is strictly a drum sampler/sound module. |
Strike for E-Drums? | jglover51 | The Drum Room | 1 | 08-31-2011 09:17 PM |
Anyone using Strike with V-drums | Wayne Dawkins | Virtual Instruments | 2 | 08-22-2010 08:48 PM |
EZ Drums Vs DrumCore Vs Strike | Dennis Scott | Virtual Instruments | 4 | 05-21-2007 11:41 PM |
Strike Virtual Drums | Brianmcnamara | Pro Tools TDM Systems (Mac) | 1 | 01-15-2007 04:13 PM |
can i use my v-drums with strike? | music project | Virtual Instruments | 6 | 11-29-2006 08:31 PM |
