Old 11-13-2017, 01:59 PM
TrentWilliams TrentWilliams is offline
Default 12.8.2 - Send Automation Faulty
Hey everyone,
Just noticed this weird automation error.
Playing back, send automation doesn't appear to be reading correctly. Playing from a nil line - no send automation works. Playing back from mid send, the automation works.
Is this happening to anyone else? I'm about to start a case.
https://streamable.com/0nese
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 11-13-2017, 02:19 PM
Drew Mazurek's Avatar
Default Re: 12.8.2 - Send Automation Faulty
This session only?
Newly created sessions also?
www.drewmazurek.com
Old 11-13-2017, 02:23 PM
Maybe I’m being a bit dense, but that looks like it’s working exactly as it should? Not sure what you mean by “nil line”.
Old 11-13-2017, 02:54 PM
Now that I've actually watched, it does appear to be working properly.
www.drewmazurek.com
Old 11-13-2017, 07:34 PM
If I play through from the automation line at '0' - the automation line moves the fader. But no information goes through the send. Look at the send meter in the video - when I play through from where the automation line is at its highest point, signal is sent through the send meter.
The line is moving the fader, but it's not sending any information through the send itself.
*watch the video with sound on, listen for the reverb and watch the meter on the send channel relative to where I play the timeline from.
Old 11-14-2017, 01:00 AM
Basstian Basstian is offline
No it does not work properly, because the fader rises as it should, but no signal is send if he starts playback from a point where the automation reads -inf.
It only works if he starts from a point where the fader ist up a bit.
I will try that here if I can recreate the issue.
EDIT: Can not recreate that. Works like it should here. No matter if i start from -inf or any other point. Fader is moving AND audio is passed.
Probably some issue with 10.13?
Old 11-14-2017, 02:58 AM
Gotcha! Sorry I didn't actually think to listen
Yes that does seem wrong, but I can't recreate here either. You could maybe export just that track as a new session and see if one of us can get it repro'd?
Old 11-14-2017, 03:13 AM
Very good idea.
Old 11-14-2017, 03:57 AM
Originally Posted by Drew Mazurek View Post
This session only?
Create new session, import track
This needs to be tried before even posting IMO.
www.drewmazurek.com
Old 11-14-2017, 10:59 AM
So I set up a duplicate send - then tried to copy the automation line over .. Which didn't work? So then I raged and deleted both sends, and set up a completely fresh one and redrew all automation. Now it works fine, glitch in the matrix apparently. Thanks for all your input everyone!
Aux send write automation bug guitarman6 Pro Tools 11 2 06-11-2014 07:36 AM
No Send Pan automation lane on 9.0.3? Craig F macOS 1 04-21-2012 12:12 PM
Can't record send automation PeterScherr Pro Tools TDM Systems (Mac) 7 02-02-2009 06:36 PM
Aux Send Automation budster Pro Tools TDM Systems (Mac) 8 04-29-2007 04:13 PM
Copying send automation szajac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-12-2005 06:05 AM
